08-05-2023 08:02 AM
After a power outage, my Ruckus router AIR light is not blinking and nor not on. The other lights from the router are on. I have tried numerous attempts to unplug, reset and even disconnect the router from the wall and connect it again. I cannot access my network name that was created for the access point, but i can access the Frontier router. How can I reconnect to my old router name? I am having trouble accessing unleashed as well.
I have a Ruckus R320 Series Unleashed
08-14-2023 11:35 AM
Hi @Ant
Please try to access the switch via console using the below guide and share the output of the following commands.
How to console in the ICX-7150-C12P:
Show flash
Show version
08-14-2023 07:47 AM
Hi @Ant
Thanks for your response.
To check this, first, we have to get access to the switch, and there are two ways to get access to the switch.
By IP address: To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router>
Show flash
Show version
08-14-2023 10:01 AM
The links don't work.
08-14-2023 10:27 AM
Hi @Ant
Sorry for the inconvenience.
Please find the below link to find the device IP address and to access the switch remotely.
08-14-2023 10:42 AM
Ok, i have went this far. where do I go from there? or is this correct?
08-14-2023 11:12 AM
I found the ip and applyed it to the other photo i provided.....
