08-05-2023 08:02 AM
After a power outage, my Ruckus router AIR light is not blinking and nor not on. The other lights from the router are on. I have tried numerous attempts to unplug, reset and even disconnect the router from the wall and connect it again. I cannot access my network name that was created for the access point, but i can access the Frontier router. How can I reconnect to my old router name? I am having trouble accessing unleashed as well.
I have a Ruckus R320 Series Unleashed
08-14-2023 11:35 AM
Hi @Ant
Please try to access the switch via console using the below guide and share the output of the following commands.
How to console in the ICX-7150-C12P:
Show flash
Show version
08-21-2023 01:12 PM
i know the switches ip address and i cannot take anymore time off of work that I arealdy have
08-21-2023 01:19 PM
Hi @Ant
Thank you for the quick response.
Apologies again.
It will not take much time. Please do it at your convivence and update me.
You could try Telnet option to log in to CLI (Putty) as described in the same guide- Please refer below
Telnet – Port 23
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
08-16-2023 08:43 AM
all those passwords didn't work
see the below pic please. this is from my internet provider and it can see the switch i think. What do I do from here if it's relevant?
08-16-2023 08:50 AM
see the couple of replies i did below. Here is this one...i went to plug in the com, and its getting me this....
08-10-2023 10:28 AM
Hi @Ant
Based on the description, the light on the AIR is off which means that access points are working fine.
Please let us know whether your internet connection is working fine or not.
Also please try to access the unleashed via web browser and let us know whether you are getting the same error or not.
