RUCKUS ICX 7150-C12P stopped working, no status LEDs on, SYST led is amber, all PoE are off
anandbellad
 I have RUCKUS ICX 7150-C12P setup in my Lennar home when brought the house in 2020. And it's been working fine until few weeks ago. When I checked, all the PoE lights are off, none of the status LEDs are on, and SYST light is amber. I restarted and nothing changed. Current, none of the IOTs are working due to this.
I have not done anything since it was setup in Jan 2020. Looking for guidance on how do I go about troubleshooting this, if there are particular sequence I should follow or directly factory reset or somethings else. I am not geek in networking but i do consider myself a handyman generally speaking and could try with some guidance.
Thank you and much appreciate any help.
Anand
2 ACCEPTED SOLUTIONS
Vásquez_Fer
Hi @anandbellad
Basically, due the power outage / spike of power /  the switch went to a state that we called (boot-mode) that is not able to boot up properly.
That does not mean is broken or need to be replace 'in some cases'
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
  1. Remove power from the switch.
If that does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted so in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
3-We need to access (physical) using one of the cables to the ICX-7150C12P mentioned on the below guide:
How to console in the ICX-7150-12cp
Once we are there, we can try to boot up the unit using the following commands:
Boot_primary or Boot_secondary
If that step does not work Software recovery needs to be applied
Here is the guide:
 https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-r...
Best Regards
Fernando Vasquez
Wael
Not everyone.
also I checked different articles and see the visitors claims about the uploading photos.
I replied with the error message.
19 REPLIES 19
Tried boot by connecting console but i keep getting error as Kernal file corrupt or not available(both primary and secondary). Then I moved on to Recovery steps, I am having issue with TFTP server connection, i have downloaded the files and setup TFTP and console but some how ping test is failing for TFTP server. I will continue to troubleshoot this.
Meanwhile, for ICX 7150 is there an option to boot and upgrade from USB drive, I am just struggling with TFTP server.
Thanks,
Anand
Hi @anandbellad
When the Switch is on boot mode the only way to recover is via TFTP server.
Please sent us a screenshot with the error :
Maybe  Windows Firewall is blocking the ping you can disable it to by pass this.
Best Regards
Fernando Vasquez
Hi Fernando,
 Apparently my RF45 cable was malfunctioning. I ordered and got the new one from Amazon and it was smooth recovery. Everything is back to life and working as it was before. Truly appreciate your responses and support/guidance(world is better place with folks like you). Thank you !
Hi @anandbellad
Great to hear that !!!
More than happy to assist you on this !
I highly recommend you  to move the switch to the recommended version base on the support site ( 8095g ) to avoid this problem or issue in the future.
There are 3 different methods to upgrade the switch
1-How to upgrade a Switch ICX7150-C12P via TFTP
Video Link as reference: https://www.youtube.com/watch?v=DHIEajPhHWQ&t=186s
2-How to perform an Upgrade via Web GUI (ICX7150 Switch)
1-How to Upgrade a Switch ICX-7150-C12P using a USB flash drive
Feel free to mark the post as solved
Best Regards
Fernando Vasquez
Hi @anandbellad
You can even copy and paste in the post as well.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
