RUCKUS ICX 7150-C12P stopped working, no status LEDs on, SYST led is amber, all PoE are off
anandbellad
 I have RUCKUS ICX 7150-C12P setup in my Lennar home when brought the house in 2020. And it's been working fine until few weeks ago. When I checked, all the PoE lights are off, none of the status LEDs are on, and SYST light is amber. I restarted and nothing changed. Current, none of the IOTs are working due to this.
I have not done anything since it was setup in Jan 2020. Looking for guidance on how do I go about troubleshooting this, if there are particular sequence I should follow or directly factory reset or somethings else. I am not geek in networking but i do consider myself a handyman generally speaking and could try with some guidance.
Thank you and much appreciate any help.
Anand
2 ACCEPTED SOLUTIONS
Vásquez_Fer
Hi @anandbellad
Basically, due the power outage / spike of power /  the switch went to a state that we called (boot-mode) that is not able to boot up properly.
That does not mean is broken or need to be replace 'in some cases'
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
  1. Remove power from the switch.
If that does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted so in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
3-We need to access (physical) using one of the cables to the ICX-7150C12P mentioned on the below guide:
How to console in the ICX-7150-12cp
Once we are there, we can try to boot up the unit using the following commands:
Boot_primary or Boot_secondary
If that step does not work Software recovery needs to be applied
Here is the guide:
 https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-r...
Best Regards
Fernando Vasquez
Wael
Not everyone.
also I checked different articles and see the visitors claims about the uploading photos.
I replied with the error message.
19 REPLIES 19
Vásquez_Fer
Hi @anandbellad
Here is the guide:
Best Regards
Fernando Vasquez
Hi Fernando,
 Thank you for the information. I tried power off/on and don't see any change. I will be doing next step to reset the ruckus but wanted to check - do I have to perform new setup after reset? , since it will be factory reset or is it just system reset
I have not done before, it was done by Lennar/Amazon person which did initial setup, not sure about all the specific details he put in. So wanted to double check.
Thanks,
Anand
Hi @anandbellad
The Factory reset will not affect the actual configuration since is done on the ICX-7150-C12P
The wireless Access Points are the devices that have all Wireless configuration ( Wi-Fi )
download.jfif
Best Regards
Fernando Vasquez
Thank you Fernando. The factory reset didn't work, LEDs kept blinking forever. I will go to next step and see what happens. Will keep posted.
