R510 no power, PoE fatal error, switch username and password not working, PWR and SYST are green
needhelp
7 ACCEPTED SOLUTIONS
Hi @needhelp
Based on the troubleshooting done, seems that the PoE port is not  responding  this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
Hi @needhelp
Please note, both Access Points need to be upgraded to the same version in order to get them connected on a single Unleashed system.
If you are unable to perform the Unleashed Upgrade online, please perform an offline/local upgrade.
And you can Upgrade to version 200.14.6.1.199 which is recently released.
Please refer to the below video showing the process of Local Upgrade.
https://www.youtube.com/watch?v=vCqiH2Aoxlk&t=66s
Thank you again.
Hi @needhelp
It seems like your ICX7150 is running 8090j code. The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin .
Please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin,
Hi @needhelp
Please perform the below commands.
configure terminal
ip address 10.106.0.10 255.255.0.0
ip default-gateway 10.106.0.1
write memory
exit
After performing the above commands, please share the output of the below command.
show ip address
ping <ip address of the master AP> (Please use IP address of the Master AP here)
Hi @needhelp
The ‘show who’ command output seems to be normal.
Please remove both the Switches from the Unleashed.
Once removed, reboot the Switch once by performing the below commands.
reload
y
And also, please reboot the Access Points as shown in the below screenshot.
Once the Access Points, Switch reboots and comes online please check the Switch status on the unleashed.
Please share the screenshot of the same.
Hi @needhelp
Yes, there will be only One Switch that will appear in the Unleashed that is trying to get in sync with the Unleashed system. Since we were trying to add manually maybe there were 2 Switches got listed previously (One trying on its own and the other one we tried to add manually).
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch as it is not getting in sync with Unleashed with the other troubleshooting steps we tried.
Please note, there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
https://docs.commscope.com/bundle/unleashed-200.9-onlinehelp/page/GUID-A887C55E-6973-4496-9413-302E8...
Hi @needhelp
Thank you for your patience.
As we checked in the private chat/posts.
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
145 REPLIES 145
The new IP address was able to ping it's self. The switch IP was changed and checked via advanced IP scanner but it shows that it is disconnected. On the unleashed dashboard it show that it is disconnected as well and I'm able to confirm the IP address was changed.
Hi @needhelp
Please share the output of the commands mentioned in my previous post.
Hi @needhelp
configure terminal
write memory
exit
show ip address
I sent you a message with the output. The first time I entered the IP default-gateway, I did not get an error message, but when I re-entered the same default-gateway a second time, I did not get an error message. I might, because it was already entered.
Hi @needhelp
Please perform the shared commands once again and try to use default-gateway as 10.106.0.1. And ping to the Master Access Points IP Address, as you tried pinging to the switch’s own IP address.
