07-13-2023 12:19 PM
07-21-2023 08:48 AM
Hi @needhelp
Based on the troubleshooting done, seems that the PoE port is not responding this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
07-27-2023 04:53 PM
Hi @needhelp
Please note, both Access Points need to be upgraded to the same version in order to get them connected on a single Unleashed system.
If you are unable to perform the Unleashed Upgrade online, please perform an offline/local upgrade.
And you can Upgrade to version 200.14.6.1.199 which is recently released.
Please refer to the below video showing the process of Local Upgrade.
https://www.youtube.com/watch?v=vCqiH2Aoxlk&t=66s
Thank you again.
08-01-2023 06:19 AM
Hi @needhelp
It seems like your ICX7150 is running 8090j code. The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin .
Please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin,
08-02-2023 04:34 PM
Hi @needhelp
Please perform the below commands.
configure terminal
ip address 10.106.0.10 255.255.0.0
ip default-gateway 10.106.0.1
write memory
exit
After performing the above commands, please share the output of the below command.
show ip address
ping <ip address of the master AP> (Please use IP address of the Master AP here)
08-03-2023 02:52 PM
Hi @needhelp
The ‘show who’ command output seems to be normal.
Please remove both the Switches from the Unleashed.
Once removed, reboot the Switch once by performing the below commands.
reload
y
And also, please reboot the Access Points as shown in the below screenshot.
Once the Access Points, Switch reboots and comes online please check the Switch status on the unleashed.
Please share the screenshot of the same.
08-03-2023 04:04 PM
Hi @needhelp
Yes, there will be only One Switch that will appear in the Unleashed that is trying to get in sync with the Unleashed system. Since we were trying to add manually maybe there were 2 Switches got listed previously (One trying on its own and the other one we tried to add manually).
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch as it is not getting in sync with Unleashed with the other troubleshooting steps we tried.
Please note, there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
08-14-2023 03:48 PM
Hi @needhelp
Thank you for your patience.
As we checked in the private chat/posts.
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
07-31-2023 09:01 AM
Hello, did you guys get this last post? Also, I wanted to remind you that once before, the second AP was labeled as master (after resetting it separately). So at one point, I had two (2) masters, but after restarting the switch and upgrading the master AP to 200.14.6.1.199, this is why the second AP is in this current status.
07-31-2023 10:28 AM
Hi @needhelp
Please confirm whether you have upgraded both the APs to the same version or not.
If yes please try to factory reset the Access points using the below link.
IMPORTANT NOTE: As you have multiple Access Points (APs) in your house, please make sure you only keep the affected AP ON and reset the same. Please go to the Ruckus Switch (located in the panel) and disconnect from its ports the Ethernet cables of the Working Access Point, except the one that you are going to work with (non-working)
Please read the following guide carefully:
If you have not able to upgrade the access points to the same version please share the screenshot of the error you are getting.
08-01-2023 01:24 AM
Yes, I was able to upgrade both APs to version 200.14.6.1.199. I'm not able to get both connected to the switch. On the web browser unleashed, it shows the master AP is the only one connected, the internet is disconnected, and the switch is disconnected. Before the upgrade, I was getting two IP addresses, one for each AP; the master is the higher-numbered IP, and the second AP is the lower-numbered IP. Now Im getting one IP address for the master.
08-01-2023 06:19 AM
Hi @needhelp
08-01-2023 07:02 AM - edited 08-01-2023 07:05 AM
Please comfirm if it is SPS08095dufi.bin or SPS08095gufi.bin. Please note that this is a 8 day old switch and it came preinstalled with 8090j code and SPS08095gufi.bin was installed on the previous switch.
