07-13-2023 12:19 PM
07-21-2023 08:48 AM
Hi @needhelp
Based on the troubleshooting done, seems that the PoE port is not responding this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
07-27-2023 04:53 PM
Hi @needhelp
Please note, both Access Points need to be upgraded to the same version in order to get them connected on a single Unleashed system.
If you are unable to perform the Unleashed Upgrade online, please perform an offline/local upgrade.
And you can Upgrade to version 200.14.6.1.199 which is recently released.
Please refer to the below video showing the process of Local Upgrade.
https://www.youtube.com/watch?v=vCqiH2Aoxlk&t=66s
Thank you again.
08-01-2023 06:19 AM
Hi @needhelp
It seems like your ICX7150 is running 8090j code. The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin .
Please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin,
08-02-2023 04:34 PM
Hi @needhelp
Please perform the below commands.
configure terminal
ip address 10.106.0.10 255.255.0.0
ip default-gateway 10.106.0.1
write memory
exit
After performing the above commands, please share the output of the below command.
show ip address
ping <ip address of the master AP> (Please use IP address of the Master AP here)
08-03-2023 02:52 PM
Hi @needhelp
The ‘show who’ command output seems to be normal.
Please remove both the Switches from the Unleashed.
Once removed, reboot the Switch once by performing the below commands.
reload
y
And also, please reboot the Access Points as shown in the below screenshot.
Once the Access Points, Switch reboots and comes online please check the Switch status on the unleashed.
Please share the screenshot of the same.
08-03-2023 04:04 PM
Hi @needhelp
Yes, there will be only One Switch that will appear in the Unleashed that is trying to get in sync with the Unleashed system. Since we were trying to add manually maybe there were 2 Switches got listed previously (One trying on its own and the other one we tried to add manually).
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch as it is not getting in sync with Unleashed with the other troubleshooting steps we tried.
Please note, there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
08-14-2023 03:48 PM
Hi @needhelp
Thank you for your patience.
As we checked in the private chat/posts.
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
08-01-2023 02:30 PM
Below is the screen shot of the disconnected switch.
08-01-2023 02:39 PM
Hi @needhelp
Could you please help me with the IP Addresses of the ICX-7150-C12P Switch and Both the Access Points.
Please do not worry, IP Addresses will be private and no once can access them outside your local network.
08-01-2023 03:26 PM
I sent you and Jayavidhya a message of the IP addresses.
08-01-2023 03:28 PM
Hi @needhelp
It happens when another AP may be getting an IP address from a different subnet and both the APs work in two different Unleashed systems.
Please check your IP settings for the access point, is it set to DHCP or static? If it’s set to static IP, there could be an IP conflict, change it to DHCP and reboot AP and check later. (Please refer to the below screenshot)
Reboot: for all the Access Points as shown in the below screenshot.
08-01-2023 04:37 PM
My web unleashed is updated and looks different than your screen shots. Both my APs was already set to DHCP. Also the second AP shares the same IP address with with the master AP. In order to view the second AP via web unleashed is by disconnecting the master cable from the switch. The WAN port was set to PORT 2 and I changed it to PORT 1 (PoE in). I will send you and Jayavidhya a screen shot.
