R510 no power, PoE fatal error, switch username and password not working, PWR and SYST are green
needhelp
7 ACCEPTED SOLUTIONS
Hi @needhelp
Based on the troubleshooting done, seems that the PoE port is not  responding  this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
Hi @needhelp
Please note, both Access Points need to be upgraded to the same version in order to get them connected on a single Unleashed system.
If you are unable to perform the Unleashed Upgrade online, please perform an offline/local upgrade.
And you can Upgrade to version 200.14.6.1.199 which is recently released.
Please refer to the below video showing the process of Local Upgrade.
https://www.youtube.com/watch?v=vCqiH2Aoxlk&t=66s
Thank you again.
Hi @needhelp
It seems like your ICX7150 is running 8090j code. The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin .
Please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin,
Hi @needhelp
Please perform the below commands.
configure terminal
ip address 10.106.0.10 255.255.0.0
ip default-gateway 10.106.0.1
write memory
exit
After performing the above commands, please share the output of the below command.
show ip address
ping <ip address of the master AP> (Please use IP address of the Master AP here)
Hi @needhelp
The ‘show who’ command output seems to be normal.
Please remove both the Switches from the Unleashed.
Once removed, reboot the Switch once by performing the below commands.
reload
y
And also, please reboot the Access Points as shown in the below screenshot.
Once the Access Points, Switch reboots and comes online please check the Switch status on the unleashed.
Please share the screenshot of the same.
Hi @needhelp
Yes, there will be only One Switch that will appear in the Unleashed that is trying to get in sync with the Unleashed system. Since we were trying to add manually maybe there were 2 Switches got listed previously (One trying on its own and the other one we tried to add manually).
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch as it is not getting in sync with Unleashed with the other troubleshooting steps we tried.
Please note, there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
https://docs.commscope.com/bundle/unleashed-200.9-onlinehelp/page/GUID-A887C55E-6973-4496-9413-302E8...
Hi @needhelp
Thank you for your patience.
As we checked in the private chat/posts.
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
145 REPLIES 145
Hi @needhelp
To find out the issue please try to upgrade the switch to the code 08095g and let us know the result.
Was able to upgrade the switch see commands results below.
On the web browser unleashed, it shows the master AP is the only one connected, the internet is disconnected, and the switch is disconnected.
The switch is a week old. LED PWR and SYST are green.
Master AP: PWR LED is blinking green; CTL LED and 2.4G are green; 5G LED is amber.
Second AP: PWR LED is blinking green; CTL LED is solid green; no other LEDs are working.
Please Enter Login Name: *****************
Please Enter Password:
User login successful.
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
UNIT 1: compiled on May 6 2022 at 23:24:50 labeled as SPS08095g
(31457280 bytes) from Primary SPS08095g.bin (UFI)
SW: Version 08.0.95gT211
Compressed Primary Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compiled on Thu Apr 21 06:08:52 2022
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:***********
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 16 minute(s) 51 second(s)
The system started at 23:26:55 GMT+00 Fri May 06 2022
The system : started=warm start reloaded=by "reload"
ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Sec Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compressed Sec Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Code Flash Free Space = 1089720320
ICX7150-C12 Switch#
Hi @needhelp
Thanks for your response.
Please verify the connections from the access points and ICX 7150 -C12 P that the cable seems to be in good conditions.
Do a factory reset (try about 3 times) on the access point that is not working to see if the lights change.
How to factory reset or factory default different type of Ruckus Access points?
https://support.ruckuswireless.com/articles/000012418
Ruckus Unleashed Set-up using your Mobile
 https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-Unleashed-Set-up-usi....
A factory reset was done on the second AP three (3) times and it does not connect to the switch.
The second AP does not coonect at all. The LEDs light up while the reset is finished and the web unleashed shows the internet and the switch is disconnected but once I connect the master AP cable back, it goes through the Configure.Me over again and finally back to the PWR LED as blinking green CTL LED is solid green with no other LEDs lite.
The master AP connects but the web unleashed shows both the internet and the switch is disconnected and it is missing the second AP.
Hi @needhelp
Please share the status of the switch showing "Switch is disconnected" in the unleashed as mentioned below.
