07-13-2023 12:19 PM
07-21-2023 08:48 AM
Hi @needhelp
Based on the troubleshooting done, seems that the PoE port is not responding this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
07-27-2023 04:53 PM
Hi @needhelp
Please note, both Access Points need to be upgraded to the same version in order to get them connected on a single Unleashed system.
If you are unable to perform the Unleashed Upgrade online, please perform an offline/local upgrade.
And you can Upgrade to version 200.14.6.1.199 which is recently released.
Please refer to the below video showing the process of Local Upgrade.
https://www.youtube.com/watch?v=vCqiH2Aoxlk&t=66s
Thank you again.
08-01-2023 06:19 AM
Hi @needhelp
It seems like your ICX7150 is running 8090j code. The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin .
Please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin,
08-02-2023 04:34 PM
Hi @needhelp
Please perform the below commands.
configure terminal
ip address 10.106.0.10 255.255.0.0
ip default-gateway 10.106.0.1
write memory
exit
After performing the above commands, please share the output of the below command.
show ip address
ping <ip address of the master AP> (Please use IP address of the Master AP here)
08-03-2023 02:52 PM
Hi @needhelp
The ‘show who’ command output seems to be normal.
Please remove both the Switches from the Unleashed.
Once removed, reboot the Switch once by performing the below commands.
reload
y
And also, please reboot the Access Points as shown in the below screenshot.
Once the Access Points, Switch reboots and comes online please check the Switch status on the unleashed.
Please share the screenshot of the same.
08-03-2023 04:04 PM
Hi @needhelp
Yes, there will be only One Switch that will appear in the Unleashed that is trying to get in sync with the Unleashed system. Since we were trying to add manually maybe there were 2 Switches got listed previously (One trying on its own and the other one we tried to add manually).
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch as it is not getting in sync with Unleashed with the other troubleshooting steps we tried.
Please note, there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
08-14-2023 03:48 PM
Hi @needhelp
Thank you for your patience.
As we checked in the private chat/posts.
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
07-19-2023 01:51 PM
Hi @needhelp
Based on the information you have shared it seems that fanless mode is enabled in your switch. Fanless mode can be enabled only if the PoE power allocation is less than or equal to 150W.
Please try to disable the fanless mode by using the following commands.
no chassis fanless all
write memory
show chassis
07-19-2023 02:21 PM
Both the PWR and SYST LEDs are green. The IP web browser username and password (super and pass) do not work. The LEDs on both access points are not on. Below are the commands that was entered.
ICX7150-C12 Switch#conf t
ICX7150-C12 Switch(config)#no chassis fanless all
Fanless mode disabled in unit(s): None
ICX7150-C12 Switch(config)#write memory
Flash Memory Write (8192 bytes per dot)
Write startup-config done.
Copy Done.
ICX7150-C12 Switch(config)#show chassis
The stack unit 1 chassis info:
Power supply 1 (AC - PoE) present, status ok
Fanless model
Slot 1 Current Temperature: 74.4 deg-C (Sensor 1), 10.0 deg-C (Sensor 2), 55.6 deg-C (Sensor 3), 60.3 deg-C (Sensor 4)
Slot 2 Current Temperature: NA
Slot 3 Current Temperature: NA
Warning level.......: 100.0 deg-C
Shutdown level......: 109.0 deg-C
Boot Prom MAC : ****.****.***4
Management MAC: ****.****.***4
07-20-2023 06:45 AM
Hi @needhelp
Thanks for your response.
Please try to enter the below commands to disable the fanless mode.
no chassis fanless 1
write memory
show chassis
07-20-2023 12:22 PM
ICX7150-C12 Switch>enable
Password:
ICX7150-C12 Switch(config)#no chassis fanless 1
Fanless model
Slot 1 Current Temperature: 73.4 deg-C (Sensor 1), 10.0 deg-C (Sensor 2), 55.3 deg-C (Sensor 3), 60.0 deg-C (Sensor 4)
Boot Prom MAC : ***.***.***4
Management MAC: ***.***.***4
07-20-2023 02:12 PM
Hi @needhelp
Please let us know whether you have any sound in your unit or not. For further troubleshoot please share the output of the following command.
"Show PoE"
Also if the default username and passwords does not work please try the most common username and passwords ( This is key sensitive so please include capital letters )
Username:admin password: Ruckus!
Username:admin password: Ruckus1
Username:admin password: Lennar
Username:super password: sp-admin
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
