06-13-2024 01:55 AM
I have the ICX-7150 which is powered on and shows green lights. I have two R510s on two different floors that wont turn on. I took one off the ceiling and connected it to a 12VDC and a different POE and it turns on but when connected to the ethernet cable coming out of the ceiling, it does not work.
06-18-2024 11:43 AM
Hello @hootanhemmat ,
Thank you for sending the query.
We understand that you are facing issues accessing CLI of the switch.
I would help you to access GUI of te switch and we would check if the PoE is disabled or now.
We would need to find the IP address of the switch and then use the IP address to login to GUI of the switch using the web browser.
Once we identify the IP address of the Switch proceed to access the RUCKUS ICX-7150-C12P Switch using a Web Browser.
Please click on Login option and try to access the Switch GUI using the login credentials.
06-19-2024 09:38 PM
06-19-2024 09:39 PM
this is where i am at. i do not see what you are sending me and i follow the links but they are not the same as what i have
I am currently on this page
can u help me
06-19-2024 09:40 PM
06-20-2024 07:56 AM
Please follow the below steps and help us with the following,
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to check if the PoE is disabled and to fix the issue if it is disabled.
Please follow the process and let me know if you need any help during the process.
