01-28-2024 09:04 PM
I’ve attempted the following but failed:
power on and off
scan for IP, no IP associated ruckus
physically connect
02-02-2024 09:58 AM
Hi @Mel27
Thanks for your response,
Good to hear that the issue got resolved.
Please feel free to mark the case as ACCEPTED SOLUTION. Also please let us know if you have any queries in this regard.
02-02-2024 04:30 AM
Hi @Mel27
Based on the information you have shared it seems like the PoE is in OFF/ disabled state as a result of which you were unable to get the ports working.
To enable the PoE on the switch please perform the below commands from the CLI.
Switch>enable
Switch#configure terminal
Switch(config-mif-1/1/1-1/1/12)#inline power
Once you perform the above process all ports should be On, and APs should get the power.
02-02-2024 09:26 AM
Hi Jayavidhya,
Here is the following results after performing the commands, please advise how to proceed
02-02-2024 09:26 AM
02-02-2024 09:27 AM
02-02-2024 09:34 AM
I ran it again and got the following, now I see the network, thank you!!
