Showing results forย
Search instead forย
Did you mean:ย
Moved to a Lennar house and need help to finish set up.
frank462
Hello everyone hope ya'll doing great.
So I moved to this Lennar house and I noticed some devices and knew they are for wifi, so started digging up and investigate on how to use them and ended factory restarted all of them.
I have a RUCKUS ICX-7150-C12P which is hard wired to my ethernet router and I did the factory reset also did all the Switch Routing Code (SPR) issue using Command Line Interface (CLI).
Also Have (2) R510 which the PWR light is blinking and the CTL is green fixed other 3 lights are off.
(1) of my R510 is still showing on my wi-fi list as Configure.me-XXXXXX while the other one does no show at all.
Downloaded the Unleashed APP and managed to configurate one of my R510 (the one that says configure.me-XXXXXX but still doesnt change to the name I gave it also its on my network inside of unleashed app that shows over there once in a while. When I check my wi-fi and network It says no internet connection.
I need help please! its driving me crazy.
1 ACCEPTED SOLUTION
Hi @frank462
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, and checking all the connectivity and connections, the failure persists. And this is the only ONE access point that isnโ€™t working even after checking with an external power adapter it behaves the same. This ONE Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
17 REPLIES 17
frank462
Already tried twice restarting the R510 from factory here some pictures . Iโ€™ll try to factory restart it again one more time following those steps.
Here some pictures.
โ€ƒ
โ€ƒ
โ€ƒ
Hi @frank462
Thank you for the update and the information.
Could you please confirm, restart means are you just trying to unplug the AP from power outlet and plug it back?
Please try to reset using a paper clip with web browser on a laptop. Refer to the below guide and video for the process.
Please confirm and let me know if you have any queries in this regard.
Sorry I meant factory reset, I did unplugged and plugged back the cable and moved it from different ports in the switch and also did the paper clip process probably 3-4 times, but Iโ€™ll have to try without the other R510 connected since I did it with it connected. Iโ€™ll update you as soon as I get home and do the process again!
Hi @frank462
Thank you for the response and the detailed explanation.
Yes, it has to be done by disconnecting the other APs. Please let me know the output once you perform the AP factory reset using web browser on a laptop.
