12-02-2022 09:51 AM
We have 2x R510 APs (one upstairs/one downstairs) and my wife's colleagues kept telling her she was dropping out momentarily every minute or so on TEAMS video calls. We've replicated this on Google Meet and Zoom also. Finally, we ran an ethernet cable directly from the Ruckus switch and that solved the issue. We also notice that our Wi-Fi TV (used with Dish Network) has momentary dropouts during all programming. This happens about every 1-2 minutes. Is there a diagnosis for this (i.e. firmware update etc.). The units were installed in Aug 2018 in a new Lennar home.
12-02-2022 09:56 AM
Hope you are doing well!
If there was a blackout or power outage and the switch reboot because of that, most possible your switch starts running the wrong code which we call ‘routing code’ this is a know issue.
MAC address: Physical address of the device this never changes
The IP address is a logical address assigned by your local router (ISP) to the device (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the IP address of the switch 'currently'
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not.
I will leave you a guide how to perform an IP scanner on your local network to identify the switch IP address very easily.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
If you can access to the Command line should look like this:
ICX7150-C12 Router>
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished )
ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command : the switch will reboot )
How to Fix Routing code issues on Lennar Home users
4-If the access via IP address is not possible here is a guide how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
Best Regards
Fernando Vasquez
12-02-2022 10:08 AM
silly question, how do I access the ruckus dashboard? when I go to unleased.ruckuswireless.com I get a dns error
12-02-2022 11:04 AM
In order to access you must be connected to the Unleashed network, now if the website does not work try with the IP address of one of your access points, let me add the guide to discover the IP address of the access points, finally you can also see with the Unleashed Application.
If you don't know the credentials, try the combination:
Username: Passwords:
admin sp-admin
Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
Yarenis Hernández
12-02-2022 02:45 PM
Hi, I’m able to connect to both APs through the Unleashed dashboard but unfortunately none of the User name & PW combos work on the switch. Do you have detailed instructions on resetting the switch password?
