07-10-2023 08:10 AM - edited 07-10-2023 08:18 AM
I have a ICX 7150 since 2020 and was never upgraded. I am at a lost as to how to locate the version and then what upgrade is necessary to use. Any help would be appreciated.
07-10-2023 08:30 AM
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
07-10-2023 03:09 PM - edited 07-10-2023 03:30 PM
The APs are still not light up.
SSH@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 On Off 0 0 n/a n/a 0 n/a
1/1/2 On Off 0 0 n/a n/a 0 n/a
1/1/3 On Off 0 0 n/a n/a 0 n/a
1/1/4 On Off 0 0 n/a n/a 0 n/a
1/1/5 On Off 0 0 n/a n/a 0 n/a
1/1/6 On Off 0 0 n/a n/a 0 n/a
1/1/7 On Off 0 0 n/a n/a 0 n/a
1/1/8 On Off 0 0 n/a n/a 0 n/a
1/1/9 On Off 0 0 n/a n/a 0 n/a
1/1/10 On Off 0 0 n/a n/a 0 n/a
1/1/11 On Off 0 0 n/a n/a 0 n/a
1/1/12 On Off 0 0 n/a n/a 0 n/a
Total 0 0
07-10-2023 03:36 PM
Hi @MiSNemesis
show version
show flash
show inline power
show interface brief
07-10-2023 03:45 PM
SSH@ICX7150-C12 Switch#show version
UNIT 1: compiled on May 6 2022 at 23:24:50 labeled as SPS08095g
(31457280 bytes) from Primary SPS08095g.bin (UFI)
SW: Version 08.0.95gT211
Compressed Primary Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compiled on Thu Apr 21 02:08:52 2022
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:FEK3203P15K
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
--More--, next page: Space, next line: Return key, quit: Control-c
SSH@ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Sec Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compressed Sec Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Code Flash Free Space = 1111490560
Total 0 0
SSH@ICX7150-C12 Switch#show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None No 1 0 78a6.e13f.aab8
1/1/2 Down None None None None No 1 0 78a6.e13f.aab9
1/1/3 Down None None None None No 1 0 78a6.e13f.aaba
1/1/4 Down None None None None No 1 0 78a6.e13f.aabb
1/1/5 Down None None None None No 1 0 78a6.e13f.aabc
1/1/6 Down None None None None No 1 0 78a6.e13f.aabd
1/1/7 Down None None None None No 1 0 78a6.e13f.aabe
1/1/8 Down None None None None No 1 0 78a6.e13f.aabf
1/1/9 Up Forward Full 1G None No 1 0 78a6.e13f.aac0
1/1/10 Down None None None None No 1 0 78a6.e13f.aac1
1/1/11 Up Forward Full 100M None No 1 0 78a6.e13f.aac2
1/1/12 Down None None None None No 1 0 78a6.e13f.aac3
1/2/1 Down None None None None No 1 0 78a6.e13f.aac5
1/2/2 Down None None None None No 1 0 78a6.e13f.aac6
1/3/1 Down None None None None No 1 0 78a6.e13f.aac7
1/3/2 Down None None None None No 1 0 78a6.e13f.aac8
mgmt1 Down None None None None No None 0 78a6.e13f.aab8
07-10-2023 04:16 PM
Supposed to be Disabled?
07-10-2023 05:01 PM
Hi @MiSNemesis
Could you please enable, apply, save and check once? (Please refer to the below screenshot)
