07-10-2023 08:10 AM - edited 07-10-2023 08:18 AM
I have a ICX 7150 since 2020 and was never upgraded. I am at a lost as to how to locate the version and then what upgrade is necessary to use. Any help would be appreciated.
07-10-2023 08:30 AM
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
07-10-2023 02:30 PM
login as: admin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SSH@ICX7150-C12 Switch>enable
SSH@ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Sec Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 1111330816
SSH@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 On Off 0 0 n/a n/a 0 n/a
1/1/2 On Off 0 0 n/a n/a 0 n/a
1/1/3 On Off 0 0 n/a n/a 0 n/a
1/1/4 On Off 0 0 n/a n/a 0 n/a
1/1/5 On Off 0 0 n/a n/a 0 n/a
1/1/6 On Off 0 0 n/a n/a 0 n/a
1/1/7 On Off 0 0 n/a n/a 0 n/a
1/1/8 On Off 0 0 n/a n/a 0 n/a
1/1/9 On Off 0 0 n/a n/a 0 n/a
1/1/10 On Off 0 0 n/a n/a 0 n/a
1/1/11 On Off 0 0 n/a n/a 0 n/a
1/1/12 On Off 0 0 n/a n/a 0 n/a
Total 0 0
--More--, next page: Space, next line: Return key, quit: Control-c
SSH@ICX7150-C12 Switch#show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None No 1 0 78a6.e13f.aab8
1/1/2 Down None None None None No 1 0 78a6.e13f.aab9
1/1/3 Down None None None None No 1 0 78a6.e13f.aaba
1/1/4 Down None None None None No 1 0 78a6.e13f.aabb
1/1/5 Down None None None None No 1 0 78a6.e13f.aabc
1/1/6 Down None None None None No 1 0 78a6.e13f.aabd
1/1/7 Down None None None None No 1 0 78a6.e13f.aabe
1/1/8 Down None None None None No 1 0 78a6.e13f.aabf
1/1/9 Up Forward Full 1G None No 1 0 78a6.e13f.aac0
1/1/10 Down None None None None No 1 0 78a6.e13f.aac1
1/1/11 Down None None None None No 1 0 78a6.e13f.aac2
1/1/12 Down None None None None No 1 0 78a6.e13f.aac3
1/2/1 Down None None None None No 1 0 78a6.e13f.aac5
1/2/2 Down None None None None No 1 0 78a6.e13f.aac6
1/3/1 Down None None None None No 1 0 78a6.e13f.aac7
1/3/2 Down None None None None No 1 0 78a6.e13f.aac8
mgmt1 Down None None None None No None 0 78a6.e13f.aab8
07-10-2023 02:41 PM
Hi @MiSNemesis
Apologies, as I observed you have upgraded to 8095j which is recently released, and we recommend Upgrading to 8095g version as mentioned previously which we consider stable version for Lennar Home users.
Could you please Upgrade to 8095g and check?
Thank you again and we appreciate your patience.
07-10-2023 02:45 PM
Can you please send me the link>?
07-10-2023 02:49 PM
Hi @MiSNemesis
Please download the file from the below drive link and upgrade.
https://drive.google.com/drive/folders/16lG-j0MSKzjqBJSY4rsgh4myUlseA9bz
Thank you again.
07-10-2023 03:08 PM
Ok, I successfully flash each partition.
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Sec Code size = 31457280, Version:08.0.95gT211 (SPS08095g.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Compressed Sec Boot Code size = 786944, Version:10.1.24T225 (mnz10124)
Code Flash Free Space = 1111580672
