11-19-2023 07:47 AM
Hi. Setting up a vsz-d on RHEL 9.2 (Rocky linux)
OS-Type: Centos 7
vsz working fine (2 member cluster)
Trying to add vsz-d guests 6.1.1 - vdp-6.1.1.0.959.qcow2
No matter what network resources (bridged / direct acttached etc) i provide the guest vm, the following error always appears after admin/admin initial login:
Fail to open /fs/shmmap/16, errno = No such file or directory
After en, setup: Waiting for network.
Whatsup?
11-22-2023 10:34 AM
Hi @dietersmith,
I can see that you have raised a Support case for this query and Support team provided you some information to follow.
Below is the perquisite Hardware Requirement and Prerequisite for vSZ-D
11-27-2023 05:47 PM
I've had the same error message while evaluating on ESXi with PCIe pass-through.
Reserved RAM needs had to be above 6GB for the VM to operate without the error.
