03-14-2024 05:55 AM
On a Smart Zone 100 controller with firmware: 6.1.1.0.959
I am trying to setup a WLAN with a WPA password and with a L3 policy that restricts access to our corporate network and L2 policy that restrict access to only certain MAC Addresses.
The problem I am having.....When putting all this together, the client keeps saying the password is incorrect but I know it is correct. I can make the WLAN unsecure and the clients can get access.
I am not sure why this would be happening. If the system allows you configure it this way then it should work, right? What am I missing?
03-17-2024 05:04 PM
Hi @brian_koomen , looks like either the L3 ACL or L2 ACL is missing an important entry. I would suggest try to use one at a moment on the WLAN and test to narrow down whether it is the L3 ACL or the L2 ACL ( first test with only applying the L3 ACL and then with L2 ACL alone and compare which scenario is working).
As for L2 ACLs, make sure that Mac-address randomization feature of clients devices is also taken into consideration as it may cause issues because of dynamic mac-address.
