08-04-2022 11:19 AM
Hi, Can you help me? I have Vsz v 5.2, two zones (3.6 and 5.2)
I have this problem:
Scenery 1
Scenery 2
08-08-2022 04:19 AM
Hello @stefany_pineda ,
A very good day to you!
Regarding your query on HotSpot and WPA2 SSID, I would first suggest:
a. Deauthorize the client from vSZ (if already connected in past)
b. Forget the SSID from the client device if trying to test within the session/grace period of the previous authentication.
2. For the HotSpot, profile, you can edit the profile and reduce the grace period to 1 min and then try to test. You have to wait for 1 min before you attempt to re-connect to HotSpot SSID to get redirected.
3. For WPA2 SSID, the controller remembers the previous authentication for a certain amount of period and hence the issue. Once you make the changes on the SSID, we always suggest forgetting the SSID on the client device before you connect to the SSID again.
Sarita Shekhar | CCNA | CWNA
Staff Technical Support Engineer,
08-12-2022 10:15 AM
Hello @das2014 ,
You can find the configuration under the Guest Profile. Screenshot attached for reference:
Let me know if this helps!
Sarita
08-12-2022 07:42 PM
Thank you!
