R550 connects to SZ but does not upgrade firmware
b_g
Hi there
I'm trying to setup a brand new AP R550 with SmartZone. The AP finds SZ IP (192.168.216.11) via DNS:
------ SCG Information ------
SCG Service is enabled.
AP is managed by SCG.
State: RUN_STATE
Server List: 192.168.216.11
SSH tunnel connected to 192.168.216.11
Failover List: Not found
Failover Max Retry: 2
DHCP Opt43 Code: 6
Server List from DHCP (Opt43/Opt52): Not found
SCG default URL: RuckusController
SCG config|heartbeat intervals: 30|30
SCG gwloss|serverloss timeouts: 1800|7200
Controller Cert Validation : disable
The AP is visible in SmartZone WebGUI, showing old firmware (114.x). Under General/Status Summary I can see the "Configuration Status" as "New Configuration", however, status does not change nor does the AP download anything. I've also checked available licenses, there are enough left.
This worked for the last APs I set up the same way, but I cannot explain why it doesn't work anymore. Did I miss something?
1 ACCEPTED SOLUTION
b_g
Solution in the end was restarting all services on the SmartZone controller:
SmartZone# service restart
Do you want to restart all services (or input 'no' to cancel)? [yes/no] yes
Restarting all services...
Process had been started before and running...
Wait for (Cassandra,Communicator,Core,Courier,ElasticSearch,Mosquitto,NginX,RabbitMQ,ScgUniversalExporter,Switchm,Web) up.
Wait for (Cassandra,Communicator,Core,Courier,Mosquitto,NginX,RabbitMQ,ScgUniversalExporter,Switchm) up.
Wait for (Communicator,Core,Courier,Mosquitto,NginX,RabbitMQ,ScgUniversalExporter,Switchm) up.
Wait for (Communicator,Core,Courier,Mosquitto,NginX,ScgUniversalExporter,Switchm) up.
Wait for (Core,Mosquitto,ScgUniversalExporter) up.
Wait for (Core,ScgUniversalExporter) up.
Wait for (Core) up.
All services are up.
Successful operation
Afterwards, the AP got the new firmware and configuration.
3 REPLIES 3
dk1089
Thank you for posting your query.
Please follow below steps and check if this works:
  • Create a new Zone specifically for this AP for onboarding.(ex Zone R550)
  • Set the zone on the latest available AP Version( which is supported by R550)
  • Create an AP Registration rule using IP address or Subnet.
  • Factory reset the AP ( CLI command :set factory-reset
  • Reboot the AP. ( CLI command : reboot)
  • Login back to the CLI and configure the AP to contact Controller : CLI : set scg ip <IP of controller>
  • When AP connects to the controller, as per registration rule, it should hit the New created zone and take the firmware from the Zone.
  • Once AP download the AP image from the zone and is stable, we can move it to the desired zone.
If this is still not working, I would request you to create a case with TAC to investigate this further.
Thank you.
Regards
Deepak Kumar
Ruckus Networks
b_g
Hi Deepak
I've followed your instructions and set up everything as suggested, but to no avail. So I opened a case with Ruckus.
b_g
Wait for (Core) up.
