05-29-2023 04:41 AM
We have configured the our configuration on zone based, if I make configuration changes in group based in wlan. Does it affect complete zone configuration.
05-29-2023 10:46 PM
Hi Sujay,
As I could see you need to know if config change on ap-group will change the config on zone.
Since we have the smart zone hierarchy as Zone>>ap-group>> AP specific, Hence if we make any changes on Zone will be applied to ap-group and ap-specific, also any change on AP-group will be applied on AP's mapped in that group and ap-specific config change is specific to only that AP but will not override ap-group or zone. Please find the below document for your reference for the same for resolution part https://support.ruckuswireless.com/articles/000009300
Archana Bollu
05-30-2023 01:38 AM
Hello @archana_bollu,
Thank you for your response. Based on our testing, we have discovered that it is not possible to override the SSID at the group level. The changes made to the SSID apply universally to all groups where it is mapped.
06-01-2023 05:53 PM
Hi Sujay,
Thankyou for the above. whenever we create an SSID initially on system level(universal) or zone or ap-group or ap-specific then we need to navigate to that level and modify the changes. Hence in your case, the SSID initially might be configured on universal level, so you can modify only from the level and that applies to all below levels.
Archana Bollu
06-01-2023 05:53 PM
Hi Sujay,
Archana Bollu
