02-28-2023 01:18 PM
My switch stopped working. After a discussion with a technician, the unit had a problem with a port.
The technician said I need a replacement. Please see more info below.
This is the serial number: FEK3217R1VM
Thanks for your reply.
Based on the troubleshooting and the images you have shared, seems that the management port is not responding this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
03-01-2023 05:50 PM
@robinparky
Thanks for providing us information.
We have initiated the RMA under case 01442941 and you will be receiving it soon.
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS
Zairah Javeed
Sr Technical Support Engineer | L2 TAC Wired
COMMSCOPE
now meets next
03-02-2023 03:54 PM - edited 03-02-2023 03:55 PM
I received a replacement. After connection, green lights are on, but no internet connection. I wonder if I connected correctly. Please let me know.
Meanwhile, when I tried my own switch, it worked fine.
03-03-2023 07:55 AM
Hi robinparky
Hope you are doing well!!!
Apologies for the delayed response on this.
As per the case description, I could understand that you are unable to access the Internet from a newly replaced Switch.
The picture/photograph you shared in which it is mentioned as a ‘Modem Connection’. Could you please confirm if it is a Modem or a Router? The connection must be from a Router or Modem-Router combo device.
Please refer to the short guide link below as a reference about how to connect the devices:
Lennar Home Community.
03-03-2023 08:12 AM
It is a modem router combo. See the connection below. Still, not working. When I tried the same connection to my personal switch, it works.
03-03-2023 09:14 AM
Hi robinparky
Apologies for the inconvenience caused.
Could you please take the console access to the Switch and share output of the below commands?
show version
show inline power
show inline power detail
Here is the guide on how to console in the ICX-7150-C12P:
