- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-02-2023 09:52 AM
Hi.
Im having some issues with all 4 of my access points and ruckus switch, after a power loss two weeks ago. the internet connection as been intermiten when devicies connect to the access points, the conection becomes on and off randombly, also making my apple devicies and window computers not connect to the internet. can some one help me with this. i tried power cycling the network switch, and the access points. i also had att replace the modem and i still have the same result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2023 06:30 PM
I found the IP of the Switch - 192.168.1.235 this was through my att router. The ip application only found my 4 AP and now switch. When going through PuTTY and connecting through the IP i get the same black screen as connected directly with the USB C on front of the switch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2023 10:39 AM
Hi @pgonzalez9 ,
Could you please confirm the models of these APs.
In such case, I would start my troubleshooting from checking if the APs are still getting sufficient power and whether they are going through random reboots when clients face issue as there was a power related incident that started this.
Could you please get the following commands from the CLI of the APs :-
1. get uptime
2. get power-mode
Md. Dilshad Zafar | Senior Technical Support Engineer
Work Hours: Mon-Fri, 9 AM to 5 PM PST
COMMSCOPE - RUCKUS
https://community.ruckuswireless.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2023 11:21 AM
Hi Zafar,
im using 4 R510 access points. I tried doing the CLI using putty and my Mac Terminal connecfion and i get unable to connect. so basded on the gui interface they been running for 22hrs 30min. as for the switch i receive this from Lennar and i belive it as already set up for someone else so i dont know the user name and password for the switch. i've also tried connectin to it using putty and telnet connction with no success.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2023 12:50 PM
Hi @pgonzalez9
As per the case description, I understand that the Internet connection from your RUCKUS devices is Intermittent after a power outage.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
Please follow the below steps and help us with the queries:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2023 06:30 PM
