Showing results forย
Search instead forย
Did you mean:ย
Wired Ethernet Connection Self-Assigned IP Issue
stu1720
I have an ICX 7150-C12 switch in my home with multiple VLANs set up.
For the 1:DEFAULT-VLAN, I have one port 1/1/4 Untagged that has been added. This port is connected to one of the two ethernet wall ports in my home office. I set this up, so I could wire connect to the switch/router/APs when I wanted to make changes on their respective browser based interfaces.
Whenever I physically connect my computer (MacBook Pro M3) to the 1/1/4 wall port, the computer self-assigns the IP and no internet or switch/router/APs connection is made. (I can connect to the interfaces using the wireless WLAN that is tied to VLAN 1.)
I have the second ethernet wall port (1/1/7 Untagged) in my office connect to my โ€œeveryday useโ€ VLAN and when I connect to that ethernet wall port, everything works fine. When I moved 1/1/7 Untagged over to 1:DEFAULT-VLAN, the computer again self-assigns the IP and does not work.
Any ideas on what I might have configured wrong?
(For what it is worth, I use an Edge Router 4 as part of my setup.)
1 ACCEPTED SOLUTION
Hi @stu1720
Thank you for your response.
We are pleased to hear that the issue has been resolved and that you were able to find a solution.
We truly appreciate your time and patience throughout this process.
Thank you again for reaching out to RUCKUS Lennar Home Community.
Should you have any further questions or concerns, please do not hesitate to contact us.
Wishing you a wonderful day ahead!
10 REPLIES 10
Imran_ruckus
Community Manager
Community Manager
Hi  @stu1720
Before we assist you, could you please let me know if this is a Lennar RUCKUS setup?
Please confirm.
Thank you again.
stu1720
Yes, this is a Lennar Ruckus setup. The home included an ICX 7150-C12 switch and two R510 APs.
test
Hi @stu1720
It sounds like you are encountering an issue where your MacBook Pro doesn't get a valid IP address when connected to a port that is part of the DEFAULT-VLAN (VLAN 1), but it works fine when connected to another VLAN (your "everyday use" VLAN). There are a few potential reasons for this issue, and I'll walk you through some troubleshooting steps to help resolve it:
1. VLAN 1 is untagged, but the switch port might not be configured correctly
  • Port configuration for VLAN 1: You've mentioned that port 1/1/4 is Untagged in the DEFAULT-VLAN (VLAN 1), which should allow it to work for the connected devices in VLAN 1. However, the configuration might not be fully correct or consistent across the switch.
  • Check VLAN Configuration on the Switch:
    • Ensure that the DEFAULT-VLAN (VLAN 1) is active and correctly configured on the switch.
    • Verify that VLAN 1 is indeed configured to allow communication on ports 1/1/4 and 1/1/7.
    • Also, make sure the Edge Router 4 is assigning IP addresses correctly through DHCP for VLAN 1. If your Edge Router 4 is connected to a different VLAN for the DHCP pool (for example, if the router is not aware of VLAN 1), your MacBook Pro wonโ€™t be able to get an IP address.
2. DHCP Issue on the Edge Router 4 for VLAN 1
If your MacBook is self-assigning an IP address (169.254.x.x range), it indicates that it's not receiving an IP address from the DHCP server. Hereโ€™s what you need to check:
  • VLAN 1 on Edge Router 4: Verify that your Edge Router 4 has a DHCP server running for VLAN 1. If it's only running for another VLAN (such as the VLAN you use for "everyday use"), your MacBook will not be able to receive an IP address in VLAN 1.
    • Log into your Edge Router 4 and verify that the DHCP settings for VLAN 1 are enabled. If DHCP isn't enabled, your devices connected to port 1/1/4 wonโ€™t get IP addresses and will resort to self-assigning.
  • VLAN Interface Setup: Ensure that the Edge Router 4 has a proper VLAN 1 interface and it's assigned an IP address that matches the network for that VLAN. For example, the router's interface for VLAN 1 should have an IP like 192.168.1.x if you're using that subnet.
3. Tagged vs. Untagged Configurations on Ports
  • Since port 1/1/4 is part of VLAN 1 (untagged), it's crucial to check if the switch's trunking and tagging setup is correct for other VLANs. When you move port 1/1/7 to VLAN 1, the same logic applies: the port must be correctly set to Untagged for VLAN 1, or the device won't get an IP.
  • Double-check how VLAN tagging is configured on all the ports, especially the ones connected to devices that should receive IP addresses via DHCP.
4. Check for Inter-VLAN Routing (If Applicable)
  • If you're using multiple VLANs and you want the Edge Router 4 to route between them (including routing traffic from VLAN 1 to the internet), ensure that Inter-VLAN routing is properly configured. If your router isn't routing between VLANs or if VLAN 1 traffic is blocked, devices on that VLAN wonโ€™t get access to the network.
5. Test with Static IP
  • As a test, try manually configuring your MacBook Pro with a static IP address in the same subnet as the router's VLAN 1 interface. This will help you verify if it's a DHCP issue specifically.
  • If static IP works but DHCP doesnโ€™t, it further confirms that the issue is with the DHCP server configuration for VLAN 1.
6. Physical Connectivity
  • Ensure that the physical wiring of the port and the device is sound. If your MacBook Pro can connect to VLAN 1 wirelessly but not through the wired connection, there might be an issue with how the switch port (1/1/4) or wall port is wired.
Suggested Steps to Resolve:
1. Verify Edge Router 4 DHCP settings: Ensure that the DHCP server is running for VLAN 1 and correctly configured.
2. Check VLAN 1 interface: On the Edge Router 4, ensure the VLAN 1 interface has a valid IP address (for example, 192.168.1.x).
3. Double-check VLAN configuration on the ICX 7150: Verify that both ports 1/1/4 and 1/1/7 are configured correctly in their respective VLANs (untagged for VLAN 1).
4. Test static IP assignment on the MacBook to see if it can connect to the network manually.
5. Ensure Inter-VLAN routing is configured (if using multiple VLANs that need routing).
By following these steps, you should be able to pinpoint the issue and get your MacBook connected to the network correctly via the wired connection on VLAN 1. Let me know how it goes.
Additionally, could you please share the outputs of the mentioned commands?
show vlan
show vlan 1
show vlan brief
show vlan ethernet 1/1/7
show running config vlan
