03-09-2025 09:12 AM
I have an ICX 7150-C12 switch in my home with multiple VLANs set up.
For the 1:DEFAULT-VLAN, I have one port 1/1/4 Untagged that has been added. This port is connected to one of the two ethernet wall ports in my home office. I set this up, so I could wire connect to the switch/router/APs when I wanted to make changes on their respective browser based interfaces.
Whenever I physically connect my computer (MacBook Pro M3) to the 1/1/4 wall port, the computer self-assigns the IP and no internet or switch/router/APs connection is made. (I can connect to the interfaces using the wireless WLAN that is tied to VLAN 1.)
I have the second ethernet wall port (1/1/7 Untagged) in my office connect to my “everyday use” VLAN and when I connect to that ethernet wall port, everything works fine. When I moved 1/1/7 Untagged over to 1:DEFAULT-VLAN, the computer again self-assigns the IP and does not work.
Any ideas on what I might have configured wrong?
(For what it is worth, I use an Edge Router 4 as part of my setup.)
03-13-2025 05:19 AM
Hi @stu1720
Thank you for your response.
We are pleased to hear that the issue has been resolved and that you were able to find a solution.
We truly appreciate your time and patience throughout this process.
Thank you again for reaching out to RUCKUS Lennar Home Community.
Should you have any further questions or concerns, please do not hesitate to contact us.
Wishing you a wonderful day ahead!
03-10-2025 05:20 AM
Hi @stu1720
Before we assist you, could you please let me know if this is a Lennar RUCKUS setup?
Please confirm.
Thank you again.
03-10-2025 06:52 AM
Yes, this is a Lennar Ruckus setup. The home included an ICX 7150-C12 switch and two R510 APs.
03-10-2025 01:52 PM
test
03-10-2025 01:54 PM
Hi @stu1720
It sounds like you are encountering an issue where your MacBook Pro doesn't get a valid IP address when connected to a port that is part of the DEFAULT-VLAN (VLAN 1), but it works fine when connected to another VLAN (your "everyday use" VLAN). There are a few potential reasons for this issue, and I'll walk you through some troubleshooting steps to help resolve it:
1. VLAN 1 is untagged, but the switch port might not be configured correctly
2. DHCP Issue on the Edge Router 4 for VLAN 1
If your MacBook is self-assigning an IP address (169.254.x.x range), it indicates that it's not receiving an IP address from the DHCP server. Here’s what you need to check:
3. Tagged vs. Untagged Configurations on Ports
4. Check for Inter-VLAN Routing (If Applicable)
5. Test with Static IP
6. Physical Connectivity
Suggested Steps to Resolve:
1. Verify Edge Router 4 DHCP settings: Ensure that the DHCP server is running for VLAN 1 and correctly configured.
2. Check VLAN 1 interface: On the Edge Router 4, ensure the VLAN 1 interface has a valid IP address (for example, 192.168.1.x).
3. Double-check VLAN configuration on the ICX 7150: Verify that both ports 1/1/4 and 1/1/7 are configured correctly in their respective VLANs (untagged for VLAN 1).
4. Test static IP assignment on the MacBook to see if it can connect to the network manually.
5. Ensure Inter-VLAN routing is configured (if using multiple VLANs that need routing).
By following these steps, you should be able to pinpoint the issue and get your MacBook connected to the network correctly via the wired connection on VLAN 1. Let me know how it goes.
Additionally, could you please share the outputs of the mentioned commands?
show vlan
show vlan 1
show vlan brief
show vlan ethernet 1/1/7
show running config vlan
