02-26-2023 04:48 PM
Had a recent power outtage and the AP's give a very weak mbps. I cannot stream or use the wifi for the phones in the house. My AT&T service is pushing 990 mbps so that's not the issue. I updated my switch to .13 reset the AP's and switch multiple times and still nothing. Very frustrating. I had issues back in 2020 and was sent another switch box and have been good until now.
02-27-2023 05:01 AM
Hi @JasonCunningham
If there was a blackout or power outage and the switch reboot because of that, most possible your switch starts running the wrong code which we call ‘routing code’ this is a known issue.
MAC address: Physical address of the device this never changes
An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the ‘currently’ IP address assigned by your local router to the switch
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not.
I will leave you a guide how to perform an IP scanner on your local network to identify the switch IP address very easily.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
If you can access to the Command line should look like this:
ICX7150-C12 Router>
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished )
ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command : the switch will reboot )
Or WEB access option
4-If the access via IP address is not possible here is a guide how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
02-28-2023 05:00 AM
This is insane! Sad really. None of these steps help me since i do not have internet. There has to be an easier way or another product that works where you don't need computer programing degree.
02-28-2023 08:22 AM
Hi @JasonCunningham
Please share the screenshot of the error you are getting while trying to solve the issue.
02-28-2023 09:38 AM
