02-23-2024 11:36 AM - edited 02-23-2024 11:38 AM
I believe I have encountered SPR issue (for the second time) due to recent power outage. I am attempting to follow instructions listed here, however, when inputting my IP address into my web browser my interface does not match that of the instructions so I am at a standstill as I'm unable to find the proper screens to make a change and correct the routing issue. See below what I receive upon inputting my IP address - closely resembles the Ruckus mobile app.
02-23-2024 01:06 PM
The Switches tab does not show any IP address information. Is there anywhere else I can reference? The Admin section shows IP addresses but again, they all match what I've been using. I'll try to reboot the switch itself in the meantime.
02-24-2024 05:38 AM
I've reset the switch and found the correct IP address. I've tried all credential combinations to login and none work. Can you share best steps?
02-24-2024 05:39 AM
02-24-2024 06:33 AM - edited 02-24-2024 06:34 AM
Hello @adambach89
Please remember that the default passwords are case-sensitive. Alternatively, you can try using the same credentials that you use for logging into the Unleashed app or web browser.
super / sp-admin
admin / Lennar
admin / lennar
admin / Ruckus!
admin / Ruckus1
admin / admin
If it doesn't work, I would recommend trying to access via Telnet with one of the applications listed in the following guide.
Fernando Vasquez
02-24-2024 07:01 AM
I'm attempting to follow instructions here, however see below as I"m getting invalid inputs? I'm on MacOS.
