07-16-2023 02:30 PM
After resetting my access point it is not showing as a master and my switch is not showing as connected. 2
07-17-2023 02:15 PM
Hi @lovebirdsoffl
May I know the reason you are trying to log into the Switch CLI using Putty?
07-17-2023 05:13 PM
Hi @lovebirdsoffl
Also, please try to reboot the Switch once (disconnect and connect the switch from the power outlet) and check the Unleashed dashboard if Switch shows connected after the reboot.
07-17-2023 07:55 PM
I have ordered the usb to rj45 cable but it won’t be here until sometime Wednesday so I will try this then thank you
07-18-2023 08:09 AM
Hi @lovebirdsoffl
You can use an Ethernet cable Or Type-C to USB for getting console access. (Please refer to the below screenshots)
OR
07-17-2023 05:16 PM
The only way I can do this is rj cable until tomorrow when I can get to a store. Will the rj cable work? I have to give up for tonight I will check back to see if I can use the rj cable and if I can do this tomorrow thanks
07-17-2023 02:29 PM - edited 07-17-2023 05:06 PM
Above is what I get after following instructions in putty.
