07-16-2023 02:30 PM
After resetting my access point it is not showing as a master and my switch is not showing as connected. 2
07-17-2023 02:15 PM
Hi @lovebirdsoffl
May I know the reason you are trying to log into the Switch CLI using Putty?
07-17-2023 02:38 PM
Hi @lovebirdsoffl
Could you please try to log in with Switch default credentials with the combination shown below:
Username: super
Password: sp-admin
Also, try different combinations as shown in the below screenshot:
07-17-2023 04:29 PM
I have tried all the usernames and passwords and still nothing. right now I cant send a screen shot because the unleashed dashboard is not working for me . I don't `know what to do next pl
07-17-2023 04:43 PM
Hi @lovebirdsoffl
Could you please download the Putty Application and try to log in to the CLI using Telnet? (Please refer to the below screenshot)
Telnet – Port 23
Please let me know once you are able to login into the Telnet, I will assist you reset the username and password for the Switch. And let me know if you have any queries in this regard.
07-17-2023 05:02 PM
07-17-2023 05:10 PM
Hi @lovebirdsoffl
If you are unable to access using Telnet or SSH, the only option left is getting console CLI access as described below.
Here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Please let me know once you are logged in to the ICX-7150-C12P using console access.
