02-16-2023 05:55 AM
I have what appears to be the switch/router issue. I need assistance accessing CLI to run the 4 commands. I can log into dashboard of my switch and i can see the disconnected issue. I identified the IP address and used Putty to login. But the command prompt is ruckus> not the expected icx7150 switch> The commands do not work with exception of enable which changes prompt from ruckus> to ruckus# I found a list of commands by typing help, but none of they listed commands to correct issue exist. I typed in sysInfo and it appears as though this is the R510...so then i am confused. Did i log into an AP instead of switch? So i checked MAC address of swtich and went back to IP scanner and confirmed IP address again.
All the information i see tells me the IP address matches the switch, but even when i log into dashboard, it identifies the Master AP?? as having the same IP address as what I assumed the switch has. I just need to get past this hurdle to enter the codes in. Any suggestions?
02-16-2023 07:48 AM - edited 02-16-2023 07:50 AM
Hi Myles,
The prompt for the ICX normally appears like this: "7150-switch or ICX-7150, etc" if you enter the CLI and get this instead: ruckus> to ruckus# you are probably in the AP and not the ICX switch, if I enter "help" in the switch it says it is an invalid command:
Switch-to-AP#
Switch-to-AP#help
Invalid input -> help
Type ? for a list
Switch-to-AP#
You can enter show sys in the AP to get the IP address and the mac address while you are in this mode:
ruckus# show sys
If you have an ICX 7150 I suggest that you access via console the switch, you need a USB type C cable for that.
02-16-2023 03:57 PM
OK...thank you for your response. It helped me confirm that I was viewing the AP instead of the switch. I also tried again to use the TypeC to USB after downloading driver and still could not get it to show up on laptop.
ISSUE:
I was still not able to access the switch. Part of the confusion was between Web GUI for switch vs the Unleashed Dashboard. These are 2 different logins with what appears to be 2 different purposes.
I also kept trying to identify the switch IP address thinking maybe i made a mistake or maybe the router assigned a different address within its range. The switch IP did not show up using Advanced IP Scanner.
SOLUTION
So I went to my Edge router to identify the port connecting to the switch and confirmed its IP address. It was what I had thought, but typing the IP in URL went nowhere, so I just unplugged all APs from switch. Of course this caused me to lose my internet so i connected laptop directly to an unused port on my router to bypass switch for this test. I then typed in the IP address of switch and IT SHOWED UP! The master AP was blocking my switch IP address?? crazy.
I then logged into Web GUI (which is not the same un + pwd as Unleashed Dashboard) and went through steps noted in previous posts and finally got it to boot from correct partition.
whew...I think feat comes close to cycling a double century 😀
02-17-2023 08:06 AM
Hi MylesFlowers
Hope you are doing well!!!
Apologies for the delayed response on this.
From the case description, I could understand that you have RUCKUS ICX-7150-C12P Switch and there are connectivity issues. And you are trying to get Switch CLI Access to perform the command.
Please refer to the links and guides later in this post to know getting CLI Access to the Switch and about fixing this issue.
This issue may happen when the Switch runs on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage may be) which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
ICX7150-C12 Router>
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command)
Example:
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
II) Or WEB access option
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '3'
Lennar Home Community.
