10-18-2023 10:52 AM
We had a recent power outage and the access point within the home are not working. In the past I have been able to power reset these systems and they reboot effectively. This time this has not worked and it seems that my Ruckus system is stuck in boot mode with an orange light for SYST and a green light for power.
I have spent a couple days looking over similar posts about this topic and have tried resetting the device and have installed the drives, upgrade, putty, MobaXterm, and other things. None of these seems to work at all and have just led to me wasting hours.
The issue with the rest and that all the lights flash orange for hours and nothing actually happpens.
The issue with doing these putty and MobaXterm and they both require the system to put in a "com" from the "ports." I have used three different computers and both the ethernet and the USB C connections and none of them have this COM show up in any circumstance.
Can someone please explain to me how to get this device out of boot mode and working. Please do not refer me to another post I have looked over the other posts on this form and it has not led to any success.
10-19-2023 05:01 AM
Hi @ClemTigers
Thank you for the response and for sharing the requested information.
This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Kind regards,
Sofia Gätjens
10-18-2023 11:55 AM
Hi @ClemTigers
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Kind regards,
Sofia Gätjens
10-18-2023 12:04 PM
1. The system has been working for ~3 years before this power outage.
2. There is an amber light on SYST and a green light on power. When I reset it, there are many amber lights flashing endlessly.
3. My internet is fine, and working.
4. There are three different access point, with no lights on any of them.
10-18-2023 01:02 PM - edited 10-18-2023 01:03 PM
Hi @ClemTigers
As you mentioned there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. And this is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
NOTE:
To access by console must install a driver so that the workstation/pc/desktop or laptop can recognize the cable
Make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file ,driver should be installed.
Link:https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Link: silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
How to console in the ICX-7150-12CP 'Ruckus Switc
Feel free to contact me if you have questions.
Kind regards,
Sofia Gätjens
10-18-2023 01:10 PM
Thank you for you response. The reset is suppose to have the flashing lights for how long? I have waited 15 hours at my longest so far.
I have already tried all of this before and it doesn't work. The issue I have with the second process is that I do not have a COM under "port" when connected. Therefore, there is no way to do the steps provided in the previous answer. Do you have other suggestions?
