Replace AP For Faster Speed
Spopky
Hi I have frontier 1 gig service but the tech told me I am limited by the access points that came with my Lennar home. I was looking to upgrade the access points but I’m not sure what my options are that will work with the ruckus switch. I think the access points might be the R510 but not positive. The faster ruckus access points are pretty pricey compared to some options on Amazon. Does anyone know what my options are here? Thanks!
5 REPLIES 5
Valued Contributor III
Hi @Spopky
Thanks for your response.
You can also try to upgrade the switch using USB flash drive or using Web GUI using the below link.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
Upgrade a switch via Web GUI (ICX7150 Switch)
