02-24-2023 04:28 PM
Hi, the Rucks r510 access point downstairs in my house is showing a Solid Red Light (the PWR Light). The one upstairs is working fine. We have attempted the physical reset process a few times and that does not render any different results. I've also pulled out the ethernet cable connected to the access point and plugged it into one of our laptops and confirmed that w/wifi access turned off on my laptop, that the ethernet cable is indeed delivering internet.
Is it likely that I may need another access point, or is the solid red light indicating that its stuck in reboot mode? Again, i've tried the physical reset several times and that has not worked, i've also tried to access the console within the Ruckus App, but the ruckus app will not allow me to login.
01-05-2024 08:47 AM - edited 01-05-2024 08:48 AM
Actually one of them was not flashing...but he other two were, the ligjt on the AP was solid red
01-05-2024 09:15 AM
Hi @asif1125
Thanks for your response,
Please try to connect the AP with 12V DC adapter and unplug the ethernet cable from the PoE port and try to perform the factory reset of the AP with the red light on it.
01-05-2024 10:21 AM
Thanks for that.
Getting it off the ceiling was the hard part, then trying to wedge the power plug in between the shell and the power connector was a slight challenge, but it seems that a full factory reset was not necessary. Just a quick tap of the reset button seemed to fix it. The green light was solo-solid for a few minutes after I hooked it back up to the POE, but then the rest of the lights started turning on, at first yellow, then back to green...I think we're good. There was no need to reset the Wifi info that was necessary to get it back into the mesh.
01-05-2024 10:48 AM
Hi @asif1125
Good to hear that the issue was resolved.
Please confirm whether the Access points are working fine or not.
01-05-2024 11:00 AM
Yes, according the Unleashed app, all three of my AP's are now connected to the mesh: Only two were when it was showing the solid red light earlier.
