11-13-2023 07:28 PM
How can we get help for icx 7150 to turn on
11-15-2023 07:18 AM
Hi @Vasayasultan
As you mentioned there are lights on the PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
We will try to reset the Switch as described below VIDEO:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
11-21-2023 12:00 PM
im confused between 8095g , and 8095h , in 2nd option
also putty what comand should i give to update
11-21-2023 12:12 PM
Hi @Vasayasultan
As explained in my Upgrade post, please use 8095g in place of 8095h and IGNORE 8080f. Directly upgrade to 8095g directly from your current version.
Please refer to my upgrade post carefully with 2nd option as everything is mentioned and let me know if you are stuck at any step.
11-21-2023 12:43 PM
i cant log in icx 7150 as super is not working how to by pass or boot in to secondary
11-21-2023 01:09 PM
Hi @Vasayasultan
If you cannot login, you could please try to log in with Switch default credentials with the combination shown below:
Username: super
Password: sp-admin
Also, try different combinations as shown in the below screenshot:
If you want to copy the version/SPC code to the secondary partition please Enter the below commands in CLI for the same:
copy flash flash secondary
Example:
11-21-2023 08:25 PM
So successful update to 8095g
but same issue can’t login to switch
I tried all the user name and password provided
but I can connect to putty with console cable if I can create username and password through that way
what would be the commas to create one
