01-02-2023 09:49 AM
a month ago, wifi was lost.
i am using att now but not reliable.
how can I get my ruckus working again? i have rebooted the router and did not work
01-02-2023 01:52 PM
Hi @J_R_K
Only one Access Point will have the CTL light on, because that will be the master.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
01-02-2023 11:22 AM
Hi @J_R_K
Please answer to the next questions in details.
1:Are the Access points getting power?
2:If the Access Points are getting power, can you connect to the SSID/Wi-Fi ID?
3:Is the SSID/Wi-Fi ID from the Access Point is slow, but the AT&T work fine?
4:Please confirm if the ICX7150 Switch SYS LED light is amber or green?
Yarenis Hernández.
01-19-2023 05:10 PM
Hello -
I believe we are experiencing a similar issue. I do not know if it was a power outage or internet outage that caused the Access Points to stop working. The white control box thing has one amber/orange light and one green light. And the 2 access points have no lights at all. What can we do to get the Access Points working again?
01-20-2023 05:07 AM
Hi @Bethany
Basically if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
If this step doesn't work, we need to perform a software recovery.
01-02-2023 11:43 AM
yes they have power
no cant connect to SSID
not working at all. i lost the wifi name totally
yes they green
