01-02-2023 09:49 AM
a month ago, wifi was lost.
i am using att now but not reliable.
how can I get my ruckus working again? i have rebooted the router and did not work
01-02-2023 01:52 PM
Hi @J_R_K
Only one Access Point will have the CTL light on, because that will be the master.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
01-02-2023 12:00 PM - edited 01-02-2023 12:01 PM
Hi @ J_R_K
1:Can you confirm what is the status of the next light in the Access Point, using the next guide to provide the details?
R510 LED lights
PWR:
2.4g:
5G:
2: Please wire a computer with an Ethernet cable to the ICX7150 Switch and confirm if you have internet with the same speed when you are connected to the AT&T router.
3:Find the IP address of the Access Points and try to gain access to the Unleashed dashboard with the IP address of the master Access Point, if you have more than one access point you will find several IP addresses so try all of them, one will bring you to the login page, the credentials are the same as the APP(I will add some default ones in case you don't know it), take in consideration that you must be connected to the AT&T internet.
Username: Passwords:
admin sp-admin
Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
4: Once you gained access to the Unleashed dashboard(you need to copy and paste the IP address of the master in the Web browser), check that the SSID is enabled and that the 2.4 and 5G signals are enabled.
Wi-Fi Networks> Edit> Advanced Options > Radio Control>Enable WLAN on>choose all to enable both radios in the SSID/Wi-Fi you choose.
Wi-Fi Networks>Edit>enable
Yarenis Hernández.
01-02-2023 12:24 PM
the pwoer is on and the CTL is sold green.
there are NO lights on 2.4G or 5 g (that is the issue)
01-02-2023 12:27 PM
Hi @J_R_K
Yes, if the 2.4 and 5G are off, can be just disable or damage, so please gain access to the Unleashed dashboard with the IP address of the Access Point.
Yarenis Hernández.
01-02-2023 11:55 AM
why would i loose the wifi name totally?
i ahve rebooted the rucksys router.
i can;t turn off the ruckus router as all the cables from the house are going to that router first and then the ATT router.
01-02-2023 12:25 PM
Hi @J_R_K
The ICX7150 is a Switch not a router, its job will be providing power to the Access point and transfer the data to the ISP AT&T router, and in any of my steps I am asking to remove a cable, you can follow up the steps as long you computer is connected via Wi-Fi to the AT&T router.
Yarenis Hernández.
