My Smart home system is not working such as no doorbell
Ariel2023
My Smart home system is not working such as no doorbell (ring) but Ruckus unit has green lights. I need help please. thank you
1 ACCEPTED SOLUTION
Ariel2023
Hi Jayavidhya,
My daughter Dar, was able to follow the step you told is to do byt what is next? We are also unable to upload the pictures of what we did…"in line power detail"
26 REPLIES 26
Dar
hi @Dar
Would you kindly relocate the cable from port #4 to any available empty port?
What was the result? After relocating the cable could you please share with me again the commands show inline power and show inline power detail?
Additionally, please access the CLI, and execute the following commands and provide the resulting output:
(Note: Press Enter after each command)
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
ICX7150-C12 Switch#show flash
Copy and paste the results on the chat (here)
Kind regards,
Sofia Gätjens
Dar
hi @Dar
Thank you for the information.
Did you follow the 1st step suggested? If not, could you please try?
--->> Would you kindly relocate the cable from port #4 to any available empty port?
Kind regards,
Sofia Gätjens
Dar
Here's the new results after relocating the cable from port #4
