My Smart home system is not working such as no doorbell
Ariel2023
My Smart home system is not working such as no doorbell (ring) but Ruckus unit has green lights. I need help please. thank you
26 REPLIES 26
Ariel2023
This one is a clear picture of lights in the unit. 
Ariel2023
Hello Jayavidhya,
I haven’t heard back from you!
Hi @Ariel2023
Sorry for the inconvenience.
As you mentioned that on your ICX-7150-C12P Switch, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are Two ways to get access to the switch.
  1. I) By IP Address of the Switch OR
  2. II) By Console Access to the Switch
  1. By IP address: To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router>
  1. Now please perform the following commands and share the output:
Show version
Show inline power
Show inline power detail
  1. By Console access: If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
Dar
We've followed the steps and here's the result. Please advise what the next steps are. Thank you!
Ports Admin-On: 12
Ports Admin-Off: 0
Ports Oper-On: 1
Ports Oper-Off: 11
Ports Off-Denied: 0
Ports Off-No-PD: 10
Ports Off-Fault: 1
Hi @Ariel2023
Thanks for your response.
Please try to login to the RUCKUS account before uploading the images and try again.
