07-08-2024 06:24 PM
Hello everyone hope ya'll doing great.
So I moved to this Lennar house and I noticed some devices and knew they are for wifi, so started digging up and investigate on how to use them and ended factory restarted all of them.
I have a RUCKUS ICX-7150-C12P which is hard wired to my ethernet router and I did the factory reset also did all the Switch Routing Code (SPR) issue using Command Line Interface (CLI).
Also Have (2) R510 which the PWR light is blinking and the CTL is green fixed other 3 lights are off.
(1) of my R510 is still showing on my wi-fi list as Configure.me-XXXXXX while the other one does no show at all.
Downloaded the Unleashed APP and managed to configurate one of my R510 (the one that says configure.me-XXXXXX but still doesnt change to the name I gave it also its on my network inside of unleashed app that shows over there once in a while. When I check my wi-fi and network It says no internet connection.
I need help please! its driving me crazy.
07-10-2024 01:13 PM
Hi @frank462
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, and checking all the connectivity and connections, the failure persists. And this is the only ONE access point that isn’t working even after checking with an external power adapter it behaves the same. This ONE Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
07-09-2024 02:19 PM
So been trying to factory reset with the paper clip but nothing happens. Still the same problem, disconnected the AP that was working and just left this one in another port and nothing. There is no Configure.me-XXXXXX like the other one in order to configúrate it. It seems like it’s death and not doing anything.
attached some pictures
07-09-2024 03:48 PM
I did the same steps as I did to the first one but it still does not work, tried everything. I made the factory reset on the switch and did all the troubleshoot, after that I did the factory reset on the first AP and managed to program it with the app and it’s working right now, but that second AP still nothing I’ve tried several times following the links provided and no results.
this is the image of the first AP
07-10-2024 06:00 AM
Hi @frank462
Thank you for your recent correspondence and update.
To further diagnose the issue with your RUCKUS R510 Access Point, I recommend the following steps:
1. Verify the Ethernet Cable: Please test with a different working Ethernet cable, as we have encountered instances where ceiling Ethernet cables have been damaged.
2. Power Testing with External Adapter: Attempt to power the R510 Access Point using an external 12 VDC adapter independent of the Switch PoE port cable. You can refer to the attached screenshot for guidance. Usually, you will find the 12 VDC adapter connected to your ISP’s (Internet Service Provider’s) Router/modem router combo device. If it powers up, please let me know which LEDs are on and what color with a picture.
Please proceed with these steps and let me know if you encounter any challenges or if you require further assistance.
Thank you for your patience and cooperation as we work towards resolving this issue.
07-10-2024 07:22 AM
Hello! Thank you for helping me through all this. So I did both method and also connected the nonworking AP in the working AP spot and nothing. Same red light comes on and then changes to green light flashing and then no lights on.
07-10-2024 07:26 AM
Hello @frank462
Thank you for your response and the information provided on the private chat.
We kindly request that you connect your affected RUCKUS R510 Access Point (AP) to a functional power outlet and share both pictures and a single video showcasing the light status, the cord connected to the APs, and its connection to a working power outlet. Please refer to the example pictures provided below for guidance.
For the video upload, we have created a designated link for your convenience. You can access it via the following link: (Refer to the EXAMPLE VIDEOS from this drive link)
If you have any questions or need further clarification, please don't hesitate to reach out.
