08-19-2023 10:38 AM
Hi, I am unable to reset ICX7150-C12 after power outage... Lights flash amber continuously and no power goes to Access Points in home. I am unable to console connect to switch using a MAC. Requesting help here. Thank you
08-21-2023 08:58 AM
Hi @Rayoub
Hope you are doing well!!!
As per the case description, I could understand that you are unable to reset your RUCKUS ICX-7150-C12P Switch which is flashing amber continuously after a power outage and Access Points have no power.
As you mentioned there are amber lights flashing. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
Please use a Windows laptop/PC for the software recovery process as there are some issue with MAC device.
08-22-2023 08:31 AM
Hi @Rayoub
Great!!! Good to know that your Switch is back to its normal behavior.
We can avoid this issue in the future by upgrading the Switch to the latest stable version.
We will check some configurations on the Switch to check your Switch's current version, please follow the below steps for the same.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
08-22-2023 08:55 AM
hi Imran, Since I do not have a windows machine. Can I upgrade the switch using the WebUI? I already have access to it. It is saying I can upgrade to 200.9.10.4.202. Is this the latest stable firmware?
08-22-2023 09:13 AM
Hi @Rayoub
I believe you are logged in to the Access Point’s Unleashed web system.
If you can log in, please help me with the screenshot showing the below information to assist you in upgrading the Switch.
Please confirm.
08-22-2023 09:34 AM
hi Imran yes I must be in the AP dashboard. but I cannot connect to the switch dashboard.
in the AP dashboard under the Switchers tab it says the Switch is disconnected. "Unleashed system only supports ICX firmware 08.0.90 or later" "Failed to ping the Switch. Suggest checking the network"
08-22-2023 12:58 PM
Hi @Rayoub
Could you please use the IP Address highlighted in the below screenshot and try to browse it on the Web browser?
