Lennar ICX7150-C12 Switch unable to reset after power outage.
Rayoub
Hi, I am unable to reset ICX7150-C12 after power outage... Lights flash amber continuously and no power goes to Access Points in home. I am unable to console connect to switch using a MAC. Requesting help here. Thank you
1 ACCEPTED SOLUTION
Imran_ruckus
Community Manager
Community Manager
Hi @Rayoub
Hope you are doing well!!!
As per the case description, I could understand that you are unable to reset your RUCKUS ICX-7150-C12P Switch which is flashing amber continuously after a power outage and Access Points have no power.
As you mentioned there are amber lights flashing. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
Please use a Windows laptop/PC for the software recovery process as there are some issue with MAC device.
36 REPLIES 36
Imran_ruckus
Community Manager
Community Manager
Hi @Rayoub
Rayoub
thank you Imran I will try the reset multiple times. I have done it about 5 times so far. I do not have a windows laptop available currently. is there another way to perform software recovery?
Hi @Rayoub
Using Windows Laptop would be easier for the software recovery process.
However, please try to reset the Switch as mentioned in my previous post and let us know if that works. We will proceed accordingly.
Rayoub
thank you Imran after about 10 resets the switch turned on and is now powering my access points.
Is there any steps I can take to prevent this from happening in the future?
Thank you.
