07-10-2023 08:10 AM - edited 07-10-2023 08:18 AM
I have a ICX 7150 since 2020 and was never upgraded. I am at a lost as to how to locate the version and then what upgrade is necessary to use. Any help would be appreciated.
07-10-2023 08:30 AM
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
07-11-2023 07:20 AM
SSH@ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
Version
00.0.0
Hardware
Version
UNKNOWN
Device HW version : 0:UNKNOWN 1:UNKNOWN
Device Temperature(deg-C) : 0:0 1:0
Device Status : 0:Failed 1:Failed
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
12 0 0 12 0 0 0
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
0 0 12 0.000 W 0.000 W
07-11-2023 07:32 AM
Hi @MiSNemesis
Based on the information you have shared, it seems that switch is not responding to any of the troubleshooting steps you have performed, this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
