07-10-2023 08:10 AM - edited 07-10-2023 08:18 AM
I have a ICX 7150 since 2020 and was never upgraded. I am at a lost as to how to locate the version and then what upgrade is necessary to use. Any help would be appreciated.
07-10-2023 08:30 AM
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
07-10-2023 12:04 PM
Hi @MiSNemesis
As I can see from the details you shared, your Switch is on the SPS08090d.bin Version.
Now please get the file SPS08095gufi.bin in place 08095hufi.bin (mentioned in the guide) file downloading it from the portal (Please refer to the below screenshot).
SPS08095gufi.bin – Pending
Please follow the below commands as mentioned in the above guide as well:
“copy tftp flash <tftp ip address> SPS08095gufi.bin primary” - (upgrade the image)
“Show flash” - (check the primary flash has the new code)
“Write memory” - (save the changes)
“boot system flash primary” - (boot the Switch with the new code)
After the Switch comes back, run the next final command to copy what is in the primary partition to the secondary because we need that both partitions match.
"copy flash flash secondary" - (will copy what is in the primary)
07-10-2023 12:45 PM - edited 07-10-2023 12:47 PM
SSH@ICX7150-C12 Switch>show flash
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Sec Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 1111314432
Looks like the Flash update worked. Only issue now after the reboot is that some of my network cables on the switch are working. My 2 APs are not powering on at all.
07-10-2023 12:54 PM
Hi @MiSNemesis
Great!!! Now your Switch is upgraded to the Latest Version.
Could you please let me know if you are able to connect to the Internet via RUCKUS Setup and Are your Access Points up?
Please confirm and let me know if you have any queries in this regard.
07-10-2023 12:56 PM
Ok, only a few lights are on. My computer can connect to the Internet but my Access points are not up.
07-10-2023 01:01 PM
Hi @MiSNemesis
show version
show flash
show inline power
show inline power detail
