11-15-2023 09:36 PM
I lost internet connection from provider due to a fiber wire that was cut and needed repair somewhere in providers end. Initially rebooted router and gained internet back from provider. Once I had my internet back I noticed my AP were not working and had no power. AP 1 and AP 2 are connected on port 1 and 2 on the switch and does not light up when plugged in. I switched ports and still no light. I’ve connected a different cat cable to ports where AP were connected and they light up so I know the ports aren’t bad. I need help with figuring out why my AP are not working. I looked through all threads and followed reset instructions and still nothing. All that CLI and doing all kind of things through computer are hard to follow. Is there an easier way for a home user to fix with hardly any IT knowledge?
11-21-2023 12:25 PM
Hi @Not_An_IT_Guy
As I see from the output you shared, your RUCKUS ICX-7150-C12P Switch is on an older SPS08060 version, and we recommend you upgrade it to a stable version.
Please follow the below steps explaining the Upgrade process.
The recommended stable version is 8095g (08.0.95g)
The Upgrade path would be: 08060 (your current version)>>8080f>>8095g
(PLEASE NOTE: Use 08095g patch in place of 8095h as explained in the guide)
Your Upgrade folder should contain these 3 files shown in the below screenshot: (Refer the guide link for more information)
Below are the options or methods to perform the Upgrade on the switch: You could choose any one of these.
1st Option:
1. In this option, we will use a pen drive or USB flash drive in which we move the files to the pen drive and connect it to the Switch then through CLI we execute the commands to upgrade the Switch using the following guide as a reference:
2nd Option:
2. The following guide is an example of an upgrade via TFTP server, by using an application (FREE) to send files or upload remote files to a device, in our case, we will use it to update a new version to the Switch, basically it will send the image version remotely from the computer to the switch.
3rd Option:
3. In this option we Upgrade the Switch from the Web Interface (GUI) of switch.
As you can access CLI, I would suggest you follow the 2nd option.
11-17-2023 10:27 AM - edited 11-17-2023 10:35 AM
ICX7150-12 Router>
Invalid input -> ICX7150-12 Router>
Type ? for a list
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Feb 17 2017 at 16:03:13 labeled as SPS08060
(23946048 bytes) from Primary
SW: Version 08.0.60T211
Compressed Boot-Monitor Image size = 786944, Version:10.1.09T225 (mnz10109)
Compiled on Sat Feb 18 00:15:43 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3226N0SZ
Current License:
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 32 minute(s) 8 second(s)
The system started at 00:01:38 GMT+00 Sat Jan 01 2000
ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 Off Off 0 0 n/a n/a 3 n/a
1/1/2 Off Off 0 0 n/a n/a 3 n/a
1/1/3 Off Off 0 0 n/a n/a 3 n/a
1/1/4 Off Off 0 0 n/a n/a 3 n/a
1/1/5 Off Off 0 0 n/a n/a 3 n/a
1/1/6 Off Off 0 0 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 0 0
ICX7150-C12 Switch#inline power detail
Invalid input -> detail
Type ? for a list
ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.2 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
--More--, next page: Space, next line: Return key, quit: Control-c^C
ICX7150-C12 Switch#
11-17-2023 10:32 AM
Hi @Not_An_IT_Guy
Could you please share a screenshot of what you are seeing?
Kind regards,
Sofia Gätjens
11-17-2023 11:39 AM
11-17-2023 10:34 AM
ICX7150-12 Router>
Type ? for a list
Current License:
1024 MB DRAM
Total 0 0
Type ? for a list
Power Supply Data:
Power Supply #1:
Max Curr: 2.2 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
General PoE Data:
Firmware
ICX7150-C12 Switch#
11-17-2023 12:38 PM
Switch>enable
Invalid input -> Switch>enable
Type ? for a list
ICX7150-C12 Switch(config-mif-1/1/1-1/1/12)#inline power
Warning: Inline power configuration on port 1/1/1 has been modified.
Warning: Inline power configuration on port 1/1/2 has been modified.
Warning: Inline power configuration on port 1/1/3 has NOT changed.
Warning: Inline power configuration on port 1/1/4 has NOT changed.
Warning: Inline power configuration on port 1/1/5 has NOT changed.
Warning: Inline power configuration on port 1/1/6 has NOT changed.
Warning: Inline power configuration on port 1/1/7 has NOT changed.
Warning: Inline power configuration on port 1/1/8 has been modified.
Warning: Inline power configuration on port 1/1/9 has NOT changed.
Warning: Inline power configuration on port 1/1/10 has NOT changed.
Warning: Inline power configuration on port 1/1/11 has NOT changed.
Warning: Inline power configuration on port 1/1/12 has been modified.
