11-15-2023 09:36 PM
I lost internet connection from provider due to a fiber wire that was cut and needed repair somewhere in providers end. Initially rebooted router and gained internet back from provider. Once I had my internet back I noticed my AP were not working and had no power. AP 1 and AP 2 are connected on port 1 and 2 on the switch and does not light up when plugged in. I switched ports and still no light. I’ve connected a different cat cable to ports where AP were connected and they light up so I know the ports aren’t bad. I need help with figuring out why my AP are not working. I looked through all threads and followed reset instructions and still nothing. All that CLI and doing all kind of things through computer are hard to follow. Is there an easier way for a home user to fix with hardly any IT knowledge?
11-21-2023 12:25 PM
Hi @Not_An_IT_Guy
As I see from the output you shared, your RUCKUS ICX-7150-C12P Switch is on an older SPS08060 version, and we recommend you upgrade it to a stable version.
Please follow the below steps explaining the Upgrade process.
The recommended stable version is 8095g (08.0.95g)
The Upgrade path would be: 08060 (your current version)>>8080f>>8095g
(PLEASE NOTE: Use 08095g patch in place of 8095h as explained in the guide)
Your Upgrade folder should contain these 3 files shown in the below screenshot: (Refer the guide link for more information)
Below are the options or methods to perform the Upgrade on the switch: You could choose any one of these.
1st Option:
1. In this option, we will use a pen drive or USB flash drive in which we move the files to the pen drive and connect it to the Switch then through CLI we execute the commands to upgrade the Switch using the following guide as a reference:
2nd Option:
2. The following guide is an example of an upgrade via TFTP server, by using an application (FREE) to send files or upload remote files to a device, in our case, we will use it to update a new version to the Switch, basically it will send the image version remotely from the computer to the switch.
3rd Option:
3. In this option we Upgrade the Switch from the Web Interface (GUI) of switch.
As you can access CLI, I would suggest you follow the 2nd option.
11-18-2023 02:10 PM
Okay, so not that I figured out how to check ports and enable them. I turned off power and plug back in and they turn off again. I tried to do a factory reset and it wont reset and this is what i get when it starts up:
Brocade Bootloader: 10.1.09T225 (Feb 17 2017 - 16:15:27 -0800)
Booted from partition 2
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0x3
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
33554432 bytes read: OK
## Loading kernel from FIT Image at 70000200 ...
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Brocade Linux MN
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x70208e64
Data Size: 2137958 Bytes = 2 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: 2c7dfff2
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x704197c8
Data Size: 19641528 Bytes = 18.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 27dad9a7
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob - Minion.dtb
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x70417570
Data Size: 8605 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: ea68dce3
Loading fdt from 0x70417570 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19c
Starting kernel ...
booting with 4.4 kernel
dd cmd: UBI
Config partition mounted
ubi1 error: ubi_io_read: error -74 (ECC error) while reading 1032192 bytes from PEB 282:16384, read 1032192 bytes
UBIFS error (ubi1:0 pid 554): ubifs_recover_leb: corrupt empty space LEB 12:8192, corruption starts at 188812
UBIFS error (ubi1:0 pid 554): ubifs_scanned_corruption: corruption at LEB 12:197004
UBIFS error (ubi1:0 pid 554): ubifs_scanned_corruption: first 8192 bytes from LEB 12:197004
UBIFS error (ubi1:0 pid 554): ubifs_recover_leb: LEB 12 scanning failed
mount: mounting ubi1:resources on /opt failed: Structure needs cleaning
Resource partition is mounted!!
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting the FastIron.
i2c-0 smbus iproc-smb-1 SMBus adapter 3
i2c-1 smbus iproc-smb-1 SMBus adapter 3
FIPS Disabled:PORT NOT DISABLED
platform type 90
OS>
Loaded Image SPS08060 from Pri Built on (UTC): Sat Feb 18 00:07:03 2017
Applying factory defaults..
INFO: startup config data is not available, try to read from backup
INFO: startup config data in the backup area is not available
set_board_level: gi_board_type = 116DMA pool size: 134217728
PHY Reset De-asserted
sw_pp_sdk_init:111 ToR init for Minion Board
SOC unit 0 attached to PCI device BCM56160_B0
Pre Parsing Config Data ...
INFO: empty config data in the primary area, try to read from backup
INFO: empty config data in the backup area also
Hotplugger Daemon Initialized ..
System initialization completed...console going online.
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Feb 17 2017 at 16:03:13 labeled as SPS08060
(23946048 bytes) from Primary
SW: Version 08.0.60T211
Compressed Boot-Monitor Image size = 786944, Version:10.1.09T225 (mnz10109)
Compiled on Sat Feb 18 00:15:43 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3226N0SZ
Current License:
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 5 second(s)
The system started at 00:01:38 GMT+00 Sat Jan 01 2000
ICX7150-C12 Switch>
ICX7150-C12 Switch>
PS 1, Internal Power supply detected.
PS 1, Internal Power supply is up.
PoE Info: Adding new 54V capacity of 124000 mW, total capacity is 124000, total free capacity is 124000
PoE Info: PoE module 1 of Unit 1 on ports 1/1/1 to 1/1/12 detected. Initializing....
PoE Event Trace Log Buffer for 2000 log entries allocated
PoE Event Trace Logging enabled...
PoE Info: PoE module 1 of Unit 1 initialization is done.
11-20-2023 05:53 AM
Hello @Not_An_IT_Guy
Could you please provide the full output of the following command: show inline power
Kind regards,
Sofia Gätjens
11-20-2023 07:03 AM
I did. look at all my replies.
11-21-2023 12:25 PM
Hi @Not_An_IT_Guy
1st Option:
2nd Option:
3rd Option:
