01-30-2022 01:19 PM
I've created a VLAN 10 and a Virtual Interface (ve 10). When I run the following command to put my ve in the Vlan, it errors out.
Command:
SSH@MYTESTSWITCH(config-vlan-10)#router-interface ve 10
Error:
Invalid input ->router-interface ve 10
Type ? for a list
Node doesn't exist
I only found one blog which mentions checking the firmware and my switch is running router firmware (SPR09010.bin) hence I'm out of ideas here now.
01-30-2022 01:35 PM
This command is no longer necessary in the 09.x firmware; every VLAN has a router interface created automatically. You should be able to use 'interface ve 10' to configure it.
01-31-2022 11:59 AM
Okay @kevin_fleming Thanks for clarifying that.
05-15-2023 03:23 PM - edited 05-15-2023 03:53 PM
This is helpful! However, when I tried to put "interface ve 1" on VLAN 1, it just takes me to that interface. Do you know why it would do this, @kpfleming? I believe I have layer 3 code:
Software Package: ICX8200_BASE_L3_SOFT_PACKAGE
SW_M (config)#vlan 1
SW_M (config-vlan-1)#interface ve 1
SW_M (config-vif-1)#
05-15-2023 06:37 PM
Hi Sydney_N,
ICX8200 has a base code of 10.x where vlans have a router interface created automatically. Hence, when you enter "interface ve 1" the prompt changes to the interface configuration mode.
Hope this helps.
05-16-2023 08:01 AM
@happytohelp thank you for clarifying!
