08-05-2022 08:58 AM
I struggled earlier this week to upgrade an ICX7450 from 9.0 to 9.0.1c and one of the things that I tried, but did not work, was to use an scp client to copy the file *to* the switch. For example,
scp SPR09010cufi.bin [email protected]:flash:sec:SPR9010cufi.bin
It's described here, too: https://docs.commscope.com/bundle/fastiron-08095-upgradeguide/page/GUID-C276A95F-9988-49A2-8159-9F18...
The file copies over ... but that it did was to create file in /home/username.
In lieu of the method described above, is there a spot to drop the file into the ICX where it will then be recognized as the primary or secondary?
Frank
08-08-2022 06:29 AM
Engineering confirmed SCP is now only allowed from FastIron CLI. External push has been blocked.
08-07-2022 07:45 AM
I did get some initial response that starting with 9.x, we only allow SCP initiated from FastIron CLI. I am working to 100% confirm that and will let you know.
08-08-2022 06:29 AM
08-08-2022 06:29 AM
Thanks for getting that clarified!
01-09-2024 09:23 PM
Hi Ben, does this "improvement" also impact our ability to use SCP to copy the config file FROM the switch? (it appears to be stopping it)
Can you please provide some reasons from technical team why they would have made this change and can you please point me to the technical docs written by Ruckus confirming this is a change. Thanks Michael.
