Upgrading ICX7450 by using SCP to copy *to* switch
frnkblk
I struggled earlier this week to upgrade an ICX7450 from 9.0 to 9.0.1c and one of the things that I tried, but did not work, was to use an scp client to copy the file *to* the switch.  For example,
scp SPR09010cufi.bin username@172.16.1.1:flash:sec:SPR9010cufi.bin
It's described here, too: https://docs.commscope.com/bundle/fastiron-08095-upgradeguide/page/GUID-C276A95F-9988-49A2-8159-9F18...
The file copies over ... but that it did was to create file in /home/username.
In lieu of the method described above, is there a spot to drop the file into the ICX where it will then be recognized as the primary or secondary?
Frank
1 ACCEPTED SOLUTION
Engineering confirmed SCP is now only allowed from FastIron CLI. External push has been blocked.
Ben Beck, RCNA, Principal Technical Support Engineer
7 REPLIES 7
I did get some initial response that starting with 9.x, we only allow SCP initiated from FastIron CLI. I am working to 100% confirm that and will let you know.
frnkblk
Thanks for getting that clarified!
