08-05-2022 08:37 AM
I'd like to better secure remote access to the ICX7450. There doesn't seem to be away to apply an ACL to the SSH configuration, so I tried both the "all-client" and "ip ssh client" commands, but they don't seem to work in 9.0? Yet they are in the online manual?
SSH@router(config)#ip ssh client <redacted IP>
Invalid input ->client <redacted IP>
Type ? for a list
Node doesn't exist
SSH@router(config)#all-client <redacted IP>
Invalid input ->199.120.69.4
Type ? for a list
Node doesn't exist
SSH@router(config)#
Frank
08-05-2022 08:46 AM
Hey @frnkblk
I think this is likely a documentation mistake. 9.x had a lot of command syntax changes. Here is the 9.x equivalent:
Please let me know if you have any questions. I will forward on the documentation error.
08-05-2022 08:46 AM
Hey @frnkblk
08-05-2022 09:39 AM
Thanks, that worked like a charm! It would be helpful if the documentation noted that when using this command there is an implicit "deny all" for everything else.
Also, can the 9.0 documentation be updated to remove "ip ssh client" and "all-client"?
08-05-2022 10:11 AM
Hey @frnkblk
No problem. I did inform the documentation team and they will work to get it updated.
