Changed image from switch to router and lost management VLAN
dawidku
Hello
I changed ICX7650 firmware image from switch to router (8.0.95k) and lost management VLAN.
I tried setting up ve interface but getting a message below:
Stack(config)#interface ve 900
Error - invalid virtual ethernet interface number
Can someone please advise
1 ACCEPTED SOLUTION
happytohelp
Hi Dawidku,
Please check if vlan 900 is created and then define ve 900 under it. Example:
device(config)# vlan 900
device(config-vlan-900)# router-interface ve 900
device(config-vlan-900)# interface ve 900
device(config-vif-900)# ip address <IP Address> <Subnet Mask>
4 REPLIES 4
happytohelp
Hi Dawidku,
dawidku
Oh that's it, thank you so much!!!
happytohelp
You're welcome. Glad to know the issue is resolved.
va10461
RUCKUS Team Member
Hi Dawidku,
This command 'router-interface ve x' is no longer necessary in the 09.x firmware; every VLAN has a router interface created automatically. You should be able to use 'interface ve 10' to configure it.
However, if you are using 8095X or below version then you need to configure 'router-interface ve x' first then 'interface ve x' commands.
Vivek Alaparthi
Staff TSE | CCNA | CCNP | RCNI
RUCKUS Networks, CommScope!
Follow me on LinkedIn
