10-25-2021 11:57 AM
I think I previously posed this in the wrong category. Sorry about that. I didn't realize initially how this forum worked.
I have a c110 that has both firmware buttons (Online Upgrade & Local Upgrade) greayed out (see screenshot). Something perhaps went wrong in an upgrade somewhere... Is there a way to start at the beginning with a known good starter firmware and reset to factory defaults. Perhaps with Putty/SSH or upgrading off of a USB thumb drive?
10-26-2021 01:03 AM
Hi David,
I would try to reset the AP from CLI (ssh),
set cm reset
If still not showing you can also factory reset the unit,
set cm factory-default
To check the status,
get cm status
Thanks.
David.
10-27-2021 08:48 AM
Before I dive in deeper. I ran a get cm status The c110 says something is "off line" and something is "Ok"
Any thoughts regarding what might be "Off line", and what might be "Ok"?
ruckus(ap-mode)# get cm status
Off line
OK
10-27-2021 11:36 AM
I did a command set cm factory-default and the device rebooted, but did not reset to factory default. all the original settings are still active.
Going to hold off on a FTP firmware push until I have a 2nd 110 backup box on standby.
ruckus(ap-mode)# set cm factory-default
OK
10-26-2021 05:08 PM
Hi David,
You can also upgrade the AP using CLI.
Use FTP or TFTP for the upgrade.
